Introduction
If your drill stops working and the battery stops holding a charge chances are you need a new battery. You can find a replacement parts including the battery under the replacement part links in the device page. This guide will show you how to install this new battery.
Remove the nine 15mm Philips #1 screws
Remove the two 12.5mm Philips #1 screws
Remove the two 10mm Philips #1 screws
Locate the battery and remove it from its slot at the end of the drill opposite the motor. It should be at the butt of the drill by the handle.
9 other people completed this guide.
10 Comments
this drill adapter, why "6V" and the adapter body is marked 9VAC output? which is true output?
Can someone test the output and tell me the voltage? VDC? VAC? thankyou.
B+D sell the replacement for ~$17
Unfortunately I do not own the drill anymore so I can't test its output. I do know that the battery used is 6V, so I would assume that is the output. Hopes this helps!
