Black and Decker WP900 Power Cord Replacement
  1. Black and Decker WP900 Power Cord Replacement, Power Cord: step 1, image 1 of 1
    • Using the plastic tool, detach the handle tab as shown.
    • Make sure the device is unplugged.
  2. Black and Decker WP900 Power Cord Replacement: step 2, image 1 of 1
    • Using the Philips #1 screwdriver, unscrew all of the screws. There should be 8-30mm screws to remove.
    • Be sure to keep track of where each screw was placed in the device for later reassembly.
  3. Black and Decker WP900 Power Cord Replacement: step 3, image 1 of 3 Black and Decker WP900 Power Cord Replacement: step 3, image 2 of 3 Black and Decker WP900 Power Cord Replacement: step 3, image 3 of 3
    • Remove the back panel of the external casing, leaving all internal components resting in the front panel.
    • Remove the black handle from the main external casing.
  4. Black and Decker WP900 Power Cord Replacement: step 4, image 1 of 1
    • Loosen the power cord and control panel. Using the Phillips #1 screwdriver, remove two 22mm screws.
    • The metal bracket will detach with the two screws.
    • Using the Flathead 3/32" screwdriver, remove two 22mm screws.
  5. Black and Decker WP900 Power Cord Replacement: step 5, image 1 of 2 Black and Decker WP900 Power Cord Replacement: step 5, image 2 of 2
    • Gently pull the power cord out from the control module.
    • This is the part to be replaced. Remember to insert the black wire into the top port when installing the new cord.
Cameron
231 Reputation
2 Guides authored
IUPUI, Team 8-8, Wilson Spring 2016 Member of IUPUI, Team 8-8, Wilson Spring 2016
IUPUI-WILSON-S16S8G8
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 291
