BlackBerry 7130e battery replacement
  1. BlackBerry 7130e battery replacement, battery: step 1, image 1 of 1
    • Turn the phone over so that the screen is facing the work surface
  2. BlackBerry 7130e battery replacement: step 2, image 1 of 1
    • Press your thumb against the battery latch. While pressing on latch, slide off battery cover towards the bottom of the phone.
    • You may need to apply considerable force on the latch at the bottom of the phone to complete this successfully.
  3. BlackBerry 7130e battery replacement: step 3, image 1 of 1
    • Remove the battery by pushing downward on the area where prongs connect to bottom inside of the phone while using a thumb, finger, or tool to pull on the top of the battery to lift it out.
Sean Tiernan
5 Reputation
5 Guides authored
Cal Poly, Team 3-16, Maness Winter 2010 Member of Cal Poly, Team 3-16, Maness Winter 2010
CPSU-MANESS-W10S3G16
4 Members
11 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 3,163
