BlackBerry 7510 Keypad Replacement
  1. BlackBerry 7510 Keypad Replacement, Back Face of Phone: step 1, image 1 of 1
    • Remove the battery cover and battery before continuing.
    • Remove the six T6 Torx screws on the back of the phone.
    • Make sure to keep the screws somewhere that they will not get lost.
  2. BlackBerry 7510 Keypad Replacement: step 2, image 1 of 1
    • Using your finger nail or a spudger, carefully pry up the back cover.
    • Begin in one spot and slowly circle around the device as you pry up all of the back cover.
  3. BlackBerry 7510 Keypad Replacement: step 3, image 1 of 1
    • Lift off the back cover.
  4. BlackBerry 7510 Keypad Replacement: step 4, image 1 of 1
    • Remove the two T6 screws.
  5. BlackBerry 7510 Keypad Replacement: step 5, image 1 of 2 BlackBerry 7510 Keypad Replacement: step 5, image 2 of 2
    • Remove the daughterboard.
    • Remove the exposed vibration motor.
  6. BlackBerry 7510 Keypad Replacement, Keypad: step 6, image 1 of 3 BlackBerry 7510 Keypad Replacement, Keypad: step 6, image 2 of 3 BlackBerry 7510 Keypad Replacement, Keypad: step 6, image 3 of 3
    • Unscrew metal plate.
    • Pry off front cover.
    • Lift off front cover to expose LCD screen.
  7. BlackBerry 7510 Keypad Replacement: step 7, image 1 of 1
    • Remove keypad from front cover and replace or fix existing pad.
Neil Johnson
12 Reputation
6 Guides authored
Cal Poly, Team 14-44, Regan Winter 2010 Member of Cal Poly, Team 14-44, Regan Winter 2010
CPSU-REGAN-W10S14G44
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 2,656
