BlackBerry 7510 LCD Screen Replacement
  1. BlackBerry 7510 LCD Screen Replacement, Back Face of Phone: step 1, image 1 of 1
    • Remove the battery cover and battery before continuing.
    • Remove the six T6 Torx screws on the back of the phone.
    • Make sure to keep the screws somewhere that they will not get lost.
  2. BlackBerry 7510 LCD Screen Replacement: step 2, image 1 of 1
    • Using your finger nail or a spudger, carefully pry up the back cover.
    • Begin in one spot and slowly circle around the device as you pry up all of the back cover.
  3. BlackBerry 7510 LCD Screen Replacement: step 3, image 1 of 1
    • Lift off the back cover.
  4. BlackBerry 7510 LCD Screen Replacement: step 4, image 1 of 1
    • Remove the two T6 screws.
  5. BlackBerry 7510 LCD Screen Replacement: step 5, image 1 of 2 BlackBerry 7510 LCD Screen Replacement: step 5, image 2 of 2
    • Remove the daughterboard.
    • Remove the exposed vibration motor.
  6. BlackBerry 7510 LCD Screen Replacement, LCD Screen: step 6, image 1 of 1
    • Unscrew the screw holding the back plate.
  7. BlackBerry 7510 LCD Screen Replacement: step 7, image 1 of 2 BlackBerry 7510 LCD Screen Replacement: step 7, image 2 of 2
    • Carefully pry off front cover. Make sure the plastic clips are unlatched before applying force.
    • Lift off front cover from metal plate.
  8. BlackBerry 7510 LCD Screen Replacement: step 8, image 1 of 1
    • Pry off the LCD screen with spudger at the two clips.
  9. BlackBerry 7510 LCD Screen Replacement: step 9, image 1 of 2 BlackBerry 7510 LCD Screen Replacement: step 9, image 2 of 2
    • Remove the LCD screen and replace it with a new one.
    • Careful not to rip the LCD ribbon.
Neil Johnson
12 Reputation
6 Guides authored
Cal Poly, Team 14-44, Regan Winter 2010 Member of Cal Poly, Team 14-44, Regan Winter 2010
CPSU-REGAN-W10S14G44
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 2,594
