BlackBerry 8700c Replacing Logic Board Replacement
  1. BlackBerry 8700c Replacing Logic Board Replacement, Replacing Logic Board: step 1, image 1 of 2 BlackBerry 8700c Replacing Logic Board Replacement, Replacing Logic Board: step 1, image 2 of 2
    • Remove the back cover by pushing down on the button and sliding the cover towards the bottom of the phone.
    • Set the cover aside. The battery will now be exposed.
  2. BlackBerry 8700c Replacing Logic Board Replacement: step 2, image 1 of 2 BlackBerry 8700c Replacing Logic Board Replacement: step 2, image 2 of 2
    • Remove the battery by pulling back on the notch on top edge of the battery.
    • Set the battery aside.
  3. BlackBerry 8700c Replacing Logic Board Replacement: step 3, image 1 of 1
    • Unscrew and remove all four T6 Torx screws.
  4. BlackBerry 8700c Replacing Logic Board Replacement: step 4, image 1 of 2 BlackBerry 8700c Replacing Logic Board Replacement: step 4, image 2 of 2
    • Pull the back cover of the phone off and set it aside.
  5. BlackBerry 8700c Replacing Logic Board Replacement: step 5, image 1 of 2 BlackBerry 8700c Replacing Logic Board Replacement: step 5, image 2 of 2
    • Unscrew and remove all 4 T6 Torx screws.
  6. BlackBerry 8700c Replacing Logic Board Replacement: step 6, image 1 of 3 BlackBerry 8700c Replacing Logic Board Replacement: step 6, image 2 of 3 BlackBerry 8700c Replacing Logic Board Replacement: step 6, image 3 of 3
    • Lift and remove inner back cover and set aside.
    • A small side piece may fall away but is simple to reattach.
    • Remove logic board by gently lifting it off of the front cover of the phone.
    • New logic board can now simply be set in place.
arlebrun
1 Reputation
1 Guide authored
Cal Poly, Team 18-4, Maness Fall 2009 Member of Cal Poly, Team 18-4, Maness Fall 2009
CPSU-MANESS-F09S18G4
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 3,244
