BlackBerry Curve 8520 Battery Replacement
  1. BlackBerry Curve 8520 Battery Replacement, Back Panel: step 1, image 1 of 2 BlackBerry Curve 8520 Battery Replacement, Back Panel: step 1, image 2 of 2
    • Insert a plastic opening tool into the small notch on the rear cover of the phone.
    • Pry the rear cover up from the phone.
  2. BlackBerry Curve 8520 Battery Replacement, Battery: step 2, image 1 of 2 BlackBerry Curve 8520 Battery Replacement, Battery: step 2, image 2 of 2
    • Locate the slit between the top of the battery and the casing.
    • Gently apply pressure on the top of the battery to trigger the spring release.
8 other people completed this guide.
Matt
1,722 Reputation
5 Guides authored
Cal Poly, Team 9-62, Walters Spring 2011 Member of Cal Poly, Team 9-62, Walters Spring 2011
CPSU-WALTERS-S11S9G62
5 Members
5 Guides authored
One Comment
very clear instructions
mirandaseagrave - Reply
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 17
All Time: 13,796
