BlackBerry Curve 8520 Motherboard Replacement
  1. BlackBerry Curve 8520 Motherboard Replacement, Back Panel: step 1, image 1 of 2 BlackBerry Curve 8520 Motherboard Replacement, Back Panel: step 1, image 2 of 2
    • Insert a plastic opening tool into the small notch on the rear cover of the phone.
    • Pry the rear cover up from the phone.
  2. BlackBerry Curve 8520 Motherboard Replacement, Battery: step 2, image 1 of 2 BlackBerry Curve 8520 Motherboard Replacement, Battery: step 2, image 2 of 2
    • Locate the slit between the top of the battery and the casing.
    • Gently apply pressure on the top of the battery to trigger the spring release.
  3. BlackBerry Curve 8520 Motherboard Replacement, Keyboard Cover: step 3, image 1 of 2 BlackBerry Curve 8520 Motherboard Replacement, Keyboard Cover: step 3, image 2 of 2
    • Remove the two Torx T6 screws to the left and right of the battery.
  4. BlackBerry Curve 8520 Motherboard Replacement: step 4, image 1 of 2 BlackBerry Curve 8520 Motherboard Replacement: step 4, image 2 of 2
    • Using hairdryer or heat gun, warm the front panel to soften the adhesive beneath.
    • Starting from one side, use a plastic opening tool to pry up the screen cover.
    • Work carefully to avoid bending the screen cover.
    • Once one side is loose, gently peel up the entire cover.
  5. BlackBerry Curve 8520 Motherboard Replacement: step 5, image 1 of 3 BlackBerry Curve 8520 Motherboard Replacement: step 5, image 2 of 3 BlackBerry Curve 8520 Motherboard Replacement: step 5, image 3 of 3
    • Insert the plastic opening tool in the seam along the side of the device.
    • Slide the tool along the length of the seam, applying moderate force with the plastic opening tool.
    • Carefully remove the faceplate.
  6. BlackBerry Curve 8520 Motherboard Replacement: step 6, image 1 of 3 BlackBerry Curve 8520 Motherboard Replacement: step 6, image 2 of 3 BlackBerry Curve 8520 Motherboard Replacement: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Remove four T6 Torx screws from the front of the phone.
    • Using tweezers, remove the keyboard buttons from the phone.
  7. BlackBerry Curve 8520 Motherboard Replacement, Motherboard: step 7, image 1 of 2 BlackBerry Curve 8520 Motherboard Replacement, Motherboard: step 7, image 2 of 2
    • Remove the two T6 Torx screws securing the small plastic bracket at the bottom of the phone.
    • Remove the four T6 Torx screws from the corners of the keyboard.
  8. BlackBerry Curve 8520 Motherboard Replacement: step 8, image 1 of 2 BlackBerry Curve 8520 Motherboard Replacement: step 8, image 2 of 2
    • Using a plastic opening tool, gently pry the motherboard assembly from the device's frame.
32 other people completed this guide.
Matt
1,722 Reputation
5 Guides authored
Cal Poly, Team 9-62, Walters Spring 2011 Member of Cal Poly, Team 9-62, Walters Spring 2011
CPSU-WALTERS-S11S9G62
5 Members
5 Guides authored
One Comment
hi sir can u provide me the dead 8520 cuvre mobile phone
hunkerbhullar - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 17
All Time: 36,842
