BlackBerry Curve 8900 Case Replacement
  1. BlackBerry Curve 8900 Case Replacement, Removing the Case: step 1, image 1 of 2 BlackBerry Curve 8900 Case Replacement, Removing the Case: step 1, image 2 of 2
    • Remove the rear cover from the phone.
    • Remove the battery.
  2. BlackBerry Curve 8900 Case Replacement, Remove the Rear Cover: step 2, image 1 of 1
    • Using a small plastic opening tool, remove the lower rear cover.
  3. BlackBerry Curve 8900 Case Replacement, Unscrew the Midframe: step 3, image 1 of 1
    • Remove the six screws from the midframe of the device.
    • Be careful not to damage the screws while removing them.
  4. BlackBerry Curve 8900 Case Replacement, Remove the Midframe: step 4, image 1 of 1
    • Remove the midframe from the phone.
  5. BlackBerry Curve 8900 Case Replacement, Remove the Motherboard: step 5, image 1 of 2 BlackBerry Curve 8900 Case Replacement, Remove the Motherboard: step 5, image 2 of 2
    • Gently pry the back the plastic tabs that secure the motherboard to the case.
    • Slowly work your way around the case with the tabs until the motherboard comes free.
    • Remove the motherboard.
    • The keypad and navigation ball may become loose and fall away from the motherboard.
Use the new case and reassemble the phone by doing the instructions in reverse order.
2 other people completed this guide.
Renae Bishop
68 Reputation
4 Guides authored
Cuesta, Team 1-3, Zipperian Fall 2011 Member of Cuesta, Team 1-3, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G3
3 Members
8 Guides authored
One Comment
Excellent, please suggest me how can I get the replacement original case shipped to Gaborone, Botswana. I also need two screws shown at the top of the cell at step 3
d.arm1965 - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 3,348
