BlackBerry Curve 8900 Keypad Replacement
  1. BlackBerry Curve 8900 Keypad Replacement, Remove the battery: step 1, image 1 of 1
    • Remove the back cover and the battery from the device.
  2. BlackBerry Curve 8900 Keypad Replacement, Remove the protective cover: step 2, image 1 of 1
    • 4 screws should be visible. Pry off the lower portion of the back to reveal all 6 screws.
  3. BlackBerry Curve 8900 Keypad Replacement, Remove the screws from the midframe: step 3, image 1 of 1
    • Remove all six T6 screws from the midframe.
  4. BlackBerry Curve 8900 Keypad Replacement, Split apart the device: step 4, image 1 of 1
    • Separate the midframe from the rest of the device.
  5. BlackBerry Curve 8900 Keypad Replacement, Remove the motherboard: step 5, image 1 of 1
    • Gently pry back the plastic tabs that secure the motherboard to the case.
    • Slowly work your way around the case prying the tabs until the motherboard comes free.
    • Remove the motherboard.
    • The keypad and navigation ball may become loose and fall away from the motherboard.
  6. BlackBerry Curve 8900 Keypad Replacement, Remove the keypad: step 6, image 1 of 3 BlackBerry Curve 8900 Keypad Replacement, Remove the keypad: step 6, image 2 of 3 BlackBerry Curve 8900 Keypad Replacement, Remove the keypad: step 6, image 3 of 3
    • Lift the keypad from the motherboard.
    • When replacing the keypad, be sure that the navigation ball is in its original position.
3 other people completed this guide.
Renae Bishop
68 Reputation
4 Guides authored
Cuesta, Team 1-3, Zipperian Fall 2011 Member of Cuesta, Team 1-3, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G3
3 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 7
All Time: 7,192
