BlackBerry KeyONE partial Disassembly
  1. BlackBerry KeyONE partial Disassembly, Remove top cover: step 1, image 1 of 1
    • Carefully remove the top plastic cover. It is held in place by adhesive.
  2. BlackBerry KeyONE partial Disassembly, Remove top frame: step 2, image 1 of 2 BlackBerry KeyONE partial Disassembly, Remove top frame: step 2, image 2 of 2
    • Remove the two Philipps #0 screws that hold in place the top of the phone frame and slide it off.
  3. BlackBerry KeyONE partial Disassembly, Remove back cover: step 3, image 1 of 1
    • Remove the back cover. It mostly just clips off, but has some adhesive in the lower area.
  4. BlackBerry KeyONE partial Disassembly, Disconnect Battery: step 4, image 1 of 2 BlackBerry KeyONE partial Disassembly, Disconnect Battery: step 4, image 2 of 2
    • Remove the two Philipps #0 screws securing the battery connector and unplug the later.
  5. BlackBerry KeyONE partial Disassembly: step 5, image 1 of 1
    • Remove the 6 Philipps #0 screws securing the lower cover and remove it.
    • Remove the three Philipps #0 screws holding down the bar that secures the two main lego-style plugs and remove it.
  6. BlackBerry KeyONE partial Disassembly, Remove top cover: step 6, image 1 of 1
    • Remove the three Philipps #0 screws securing the upper cover and remove it.
  7. BlackBerry KeyONE partial Disassembly: step 7, image 1 of 1
    • Unplug the remaining ribbon cables
    • Remove the last three Philipps #0 screws securing the Motherbard.
    • Now you should be able to replace most components.
    • The screen is held in place from the front by adhesive (or not, in the earlier versions), its cable slides trough the phone to the PCB - It's the large connector in the middle.
    • The battery is glued to the frame firmly. There are three pultabs located underneath the motherboard.
    • Don't forget to remove the sim-tray if you're removing the motherboard.
15 other people completed this guide.
raven
1,110 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 47
All Time: 10,512
