BlackBerry Pearl 8100 Screen Replacement
  1. BlackBerry Pearl 8100 Screen Replacement, Battery: step 1, image 1 of 1
    • Before working on the phone, be sure that the device is turned off.
    • Begin by removing the back panel; this can be done by pressing the silver button on the backside of the Blackberry 8100, while simultaneously sliding the back panel off.
    • Remove the battery located directly below back panel.
  2. BlackBerry Pearl 8100 Screen Replacement, Keyboard: step 3, image 1 of 1
    • Using a 1.5 mm Hex screwdriver, remove the two screws that hold the two panels together.
  3. BlackBerry Pearl 8100 Screen Replacement: step 4, image 1 of 2 BlackBerry Pearl 8100 Screen Replacement: step 4, image 2 of 2
    • Using the spudger, pry off the small portion of the casing located at the bottom of the phone.
  4. BlackBerry Pearl 8100 Screen Replacement: step 5, image 1 of 1
    • Using the spudger, pry off the side casings one at a time by wedging it between the inner casing and the sides.
  5. BlackBerry Pearl 8100 Screen Replacement: step 6, image 1 of 1
    • Using a 1.5mm Hex screwdriver, unscrew the two screws, located on the front of the phone, that connect the back and front panels.
  6. BlackBerry Pearl 8100 Screen Replacement: step 7, image 1 of 2 BlackBerry Pearl 8100 Screen Replacement: step 7, image 2 of 2
    • Using the spudger, pry off the back body panel by wedging the spudger in between the front and back panels on the side face. Remove the back body panel.
  7. BlackBerry Pearl 8100 Screen Replacement: step 8, image 1 of 1
    • Separate the logic board from the front panel.
  8. BlackBerry Pearl 8100 Screen Replacement: step 9, image 1 of 2 BlackBerry Pearl 8100 Screen Replacement: step 9, image 2 of 2
    • Gently remove the keyboard from front casing. It should snap out of place.
  9. BlackBerry Pearl 8100 Screen Replacement, Screen: step 10, image 1 of 1
    • After removing the logic board, place spudger between the logic board and screen and remove the screen, sliding it slowly away.
2 other people completed this guide.
Robert Cronin
544 Reputation
6 Guides authored
Cal Poly, Team 34-57, Forte Spring 2010 Member of Cal Poly, Team 34-57, Forte Spring 2010
CPSU-FORTE-S10S34G57
5 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 2,832
