BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball
  1. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball, Circuit Board and Roller Ball: step 1, image 1 of 3 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball, Circuit Board and Roller Ball: step 1, image 2 of 3 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball, Circuit Board and Roller Ball: step 1, image 3 of 3
    • Remove four screws total on the back of the phone casing near edge of battery area.
    • Two screws that are closer to the top of the phone are protected by plastic stoppers. Remove them then remove the screws.
    • There are two more screws on either side of where the battery was located. remove them as well.
  2. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: step 2, image 1 of 3 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: step 2, image 2 of 3 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: step 2, image 3 of 3
    • Remove the bottom plastic piece.
    • This may require prying from a few different directions. The plastic blue prying tool featured here may be required.
  3. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: step 3, image 1 of 3 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: step 3, image 2 of 3 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: step 3, image 3 of 3
    • Once the keypad is removed, the buttons on the sides of the phone will fall out.
    • You will need to loosen the board from the right side opposite the charging ports.
    • Pull gently towards the right side so the ports clear the plastic casing.
    • Gently flip the board over to the left.
  4. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: step 4, image 1 of 3 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: step 4, image 2 of 3 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: step 4, image 3 of 3
    • On the back of the circuit board you will find a small rectangular blue piece with a black 'L' shape in the middle.
    • Gently detach this from the back of the main board.
    • Now you may fully remove the main board.
  5. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: step 5, image 1 of 3 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: step 5, image 2 of 3 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: step 5, image 3 of 3
    • What is left inside the phone is the roller ball.
    • Gently use the plastic blue tool to detach it from the frame.
Ashley
318 Reputation
3 Guides authored
SUNY Cortland, Team 1-5, Getto Spring 2013 Member of SUNY Cortland, Team 1-5, Getto Spring 2013
SUNYCORT-GETTO-S13S1G5
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 829
