BlackBerry Torch 9850 Battery Replacement
  1. BlackBerry Torch 9850 Battery Replacement, Battery: step 1, image 1 of 1
    • Power off the device.
    • Press and hold down the power/end button on the phone until phone powers off and the screen goes black.
  2. BlackBerry Torch 9850 Battery Replacement: step 2, image 1 of 2 BlackBerry Torch 9850 Battery Replacement: step 2, image 2 of 2
    • Remove the plastic cover that would normally be on the back of the phone.
    • Press down on the release button, which is located on the bottom of the back side of the phone.
    • Lift up on the plastic covering and remove.
  3. BlackBerry Torch 9850 Battery Replacement: step 3, image 1 of 3 BlackBerry Torch 9850 Battery Replacement: step 3, image 2 of 3 BlackBerry Torch 9850 Battery Replacement: step 3, image 3 of 3
    • Remove the battery.
    • Once the plastic covering is removed, you can remove the battery.
    • Use your fingers or a plastic spudger to pop the bottom of the battery out of its place by pushing and lifting.
    • Once the bottom of the battery has ejected, you can easily remove the whole battery from the phone with your hands.
  4. BlackBerry Torch 9850 Battery Replacement: step 4, image 1 of 2 BlackBerry Torch 9850 Battery Replacement: step 4, image 2 of 2
    • Inserting a new battery.
    • Align the plus and minus signs at the top of the battery compartment with the plus and minus signs at the top of the battery.
    • Push battery into place.
    • Replace the plastic cover by snapping into place.
Rachel Staigerwald
712 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 592
