Introduction
If your trackball is unresponsive or damaged, then you will need to replace it. Use these step-by-step instructions to replace your trackball on a Blackberry Tour 9630.
Position the phone so that the keyboard is facing down and the back is facing up.
If there is an SD card, press gently on the card and slide it up to remove.
If there is a SIM card, press gently on the card and slide it left to remove.
Use the T6 Torx screwdriver to remove the four 8.00 mm screws from the back of the phone.
