BlackBerry Z30 Logic board Replacement
  1. BlackBerry Z30 Logic board Replacement, Battery cover: step 1, image 1 of 1
    • Remove the battery cover by grabbing the notch under the bottom speakers and lifting.
  2. BlackBerry Z30 Logic board Replacement, Remove SIM and Media Card: step 2, image 1 of 1
    • Remove the SIM card and the Media SD card by pushing on them.
  3. BlackBerry Z30 Logic board Replacement, Unscrewing the LCD panel: step 3, image 1 of 3 BlackBerry Z30 Logic board Replacement, Unscrewing the LCD panel: step 3, image 2 of 3 BlackBerry Z30 Logic board Replacement, Unscrewing the LCD panel: step 3, image 3 of 3
    • Locate and unscrew all 10 T5 screws around the back cover
  4. BlackBerry Z30 Logic board Replacement, Separate the LCD from the Frame: step 4, image 1 of 2 BlackBerry Z30 Logic board Replacement, Separate the LCD from the Frame: step 4, image 2 of 2
    • Use Plastic opening tools to separate the LCD from the Main body
    • Do NOT remove the screen yet, it is attached with a very fragile ribbon to the main board.
    • Start on the same side of the Audio Jack
  5. BlackBerry Z30 Logic board Replacement, Remove the LCD: step 5, image 1 of 2 BlackBerry Z30 Logic board Replacement, Remove the LCD: step 5, image 2 of 2
    • Use a plastic tool to carefully switch up the LCD ribbon holder
    • Detach the LCD from the main board
    • When installing the new LCD, make sure the ribbon is inserted to the white line.
  6. BlackBerry Z30 Logic board Replacement, LCD Panel removal: step 6, image 1 of 1
    • You can now detach the LCD Panel from the main frame.
  7. BlackBerry Z30 Logic board Replacement, Untie the System board: step 7, image 1 of 1
    • With a plastic tool, untie the system board by detaching the ribbons attached to it
    • The battery ribbon is on the bottom right
    • Be gentle when detaching these Ribbons as they are very easy to tear and damage.
  8. BlackBerry Z30 Logic board Replacement, Untie the System board Part 2: step 8, image 1 of 1
    • Be gentle as any other system board ribbons, they are very easy to damage
  9. BlackBerry Z30 Logic board Replacement, Untie the system board Part 3: step 9, image 1 of 1
    • Power Button /Audio Jack
    • Flash
    • Rear Facing Camera
  10. BlackBerry Z30 Logic board Replacement, System board removal: step 10, image 1 of 1
    • Once all Ribbons untied, gently wiggle the system board out of the frame
    • Do not pull hard as there might be a ribbon on the way
4 other people completed this guide.
Hans
1,926 Reputation
6 Guides authored
Mero IT Services Member of Mero IT Services
Business
1 Member
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 4,048
