Blackberry 7105t LCD Replacement
  1. Blackberry 7105t LCD Replacement, Blackberry 7105t Disassembly: step 1, image 1 of 1
    • With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
  2. Blackberry 7105t LCD Replacement: step 2, image 1 of 1
    • Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
  3. Blackberry 7105t LCD Replacement: step 3, image 1 of 1
    • Remove the battery by pushing against it from the right and then pulling towards you.
  4. Blackberry 7105t LCD Replacement: step 4, image 1 of 1
    • Remove the four screws indicated in the picture with a #T6 Torx Bit screwdriver and set them aside.
  5. Blackberry 7105t LCD Replacement: step 5, image 1 of 3 Blackberry 7105t LCD Replacement: step 5, image 2 of 3 Blackberry 7105t LCD Replacement: step 5, image 3 of 3
    • Use a plastic opening tool or your fingernails to remove the plastic backing.
    • Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated.
  6. Blackberry 7105t LCD Replacement: step 6, image 1 of 1
    • Unscrew the four screws indicated in the picture with #T6 Torx Bit screwdriver.
    • Place the four screws released from the phone in a plastic bag.
  7. Blackberry 7105t LCD Replacement: step 7, image 1 of 1
    • The black battery casing and logic board can now be separated for the following steps.
  8. Blackberry 7105t LCD Replacement, Second Disassembly: step 8, image 1 of 1
    • The silver piece is not attached to the logic board in any way, and can be taken off by lifting it up with plastic opening tools.
    • Warning: Some of the phones have an adhesive between the silver part and the battery housing, so it could stick to the black piece you just removed.
  9. Blackberry 7105t LCD Replacement, Keyboard: step 9, image 1 of 2 Blackberry 7105t LCD Replacement, Keyboard: step 9, image 2 of 2
    • Use a plastic opening tool to lift up the two black clips indicated in the picture.
    • Hold on to the keyboard while unfastening the clips.
    • The keyboard will detach once the clips are unfastened.
  10. Blackberry 7105t LCD Replacement, LCD: step 10, image 1 of 1
    • With the screen facing you, you will be able to see a small grey plastic clip.
    • Use a plastic opening tool to unfasten the clip as shown.
  11. Blackberry 7105t LCD Replacement: step 11, image 1 of 2 Blackberry 7105t LCD Replacement: step 11, image 2 of 2
    • Flip the logic board over to the other side.
    • Use a plastic opening tool unclip the top two clips shown in red, and then the bottom two clips. This releases the screen.
    • Flip logic board over and remove screen.
    • Make sure to hold the screen, it could fall after being unclipped.
  12. Blackberry 7105t LCD Replacement: step 12, image 1 of 1
    • NOTE: If you are not replacing the LCD screen, move on to the next step.
    • After removing the original screen, keep the logic board facing you the way it was.
    • Take the new screen and slip the flexible piece of connecting circuitry under the grey plastic flap that you pried up in step 10.
    • Handle the screen carefully as it is fragile.
    • Push it gently but firmly until it does not move any further to the left, then close the grey flap.
    • After this, the screen can be pushed down and clicked back into place.
    • To reassemble the phone, reverse instructions.
Finish Line
CeeJay
19 Reputation
5 Guides authored
Cal Poly, Team 9-17, Regan Fall 2009 Member of Cal Poly, Team 9-17, Regan Fall 2009
CPSU-REGAN-F09S9G17
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 2,142
