Blackberry 7520 LCD Screen Replacement
  1. Blackberry 7520 LCD Screen Replacement, Battery: step 1, image 1 of 2 Blackberry 7520 LCD Screen Replacement, Battery: step 1, image 2 of 2
    • Turn the phone upside down.
    • Push down on the black button on the back of the phone to slide the rear panel off.
    • The battery should be visible now.
  2. Blackberry 7520 LCD Screen Replacement: step 2, image 1 of 3 Blackberry 7520 LCD Screen Replacement: step 2, image 2 of 3 Blackberry 7520 LCD Screen Replacement: step 2, image 3 of 3
    • Hold the BlackBerry in one hand face-up with the screen facing towards you.
    • Gently smack the phone against your hand to dislodge the battery.
  3. Blackberry 7520 LCD Screen Replacement, Motherboard: step 3, image 1 of 2 Blackberry 7520 LCD Screen Replacement, Motherboard: step 3, image 2 of 2
    • Use a T6 Torx screwdriver to remove the 6 screws holding the rear of the phone.
  4. Blackberry 7520 LCD Screen Replacement: step 4, image 1 of 2 Blackberry 7520 LCD Screen Replacement: step 4, image 2 of 2
    • Use a pick or plastic opening tool to push the clips holding the rear away from you.
    • Applying too much pressure could break the plastic clips and permanently damage your Blackberry.
  5. Blackberry 7520 LCD Screen Replacement: step 5, image 1 of 1
    • Repeat the process of unlatching the clips for the top section of the Blackberry.
  6. Blackberry 7520 LCD Screen Replacement: step 6, image 1 of 2 Blackberry 7520 LCD Screen Replacement: step 6, image 2 of 2
    • Slide the rear panel forward to reveal the motherboard.
  7. Blackberry 7520 LCD Screen Replacement: step 7, image 1 of 2 Blackberry 7520 LCD Screen Replacement: step 7, image 2 of 2
    • Remove the indicated screws using a T6 Torx screwdriver.
  8. Blackberry 7520 LCD Screen Replacement: step 8, image 1 of 2 Blackberry 7520 LCD Screen Replacement: step 8, image 2 of 2
    • Remove the motherboard.
    • Remove the indicated screw using the T6 Torx screwdriver.
  9. Blackberry 7520 LCD Screen Replacement: step 9, image 1 of 2 Blackberry 7520 LCD Screen Replacement: step 9, image 2 of 2
    • Pull the metal plate away from the front panel of the cell phone.
  10. Blackberry 7520 LCD Screen Replacement: step 10, image 1 of 1
    • Place the faceplate face-down and the interior of the phone face-up, as shown.
  11. Blackberry 7520 LCD Screen Replacement, LCD Screen: step 11, image 1 of 1
    • Turn the phone so that it faces towards you.
  12. Blackberry 7520 LCD Screen Replacement: step 12, image 1 of 1
    • Use a pick or other small tool to pop the small plastic clip holding the LCD panel on
  13. Blackberry 7520 LCD Screen Replacement: step 13, image 1 of 2 Blackberry 7520 LCD Screen Replacement: step 13, image 2 of 2
    • Pull the LCD screen off of the board.
Nathan
31 Reputation
6 Guides authored
Cal Poly, Team 5-7, Forte Winter 2010 Member of Cal Poly, Team 5-7, Forte Winter 2010
CPSU-FORTE-W10S5G7
5 Members
9 Guides authored
One Comment
It’s too bad that iFixit didn’t post a teardown listing the parts for the BlackBerry 7520, since so little is known about its parts.
amosbatto - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 1,449
