Blackberry Bold 9000 Antenna Replacement
  1. Blackberry Bold 9000 Antenna Replacement, Battery: step 1, image 1 of 1
    • Place your Blackberry facedown in front of you.
  2. Blackberry Bold 9000 Antenna Replacement: step 2, image 1 of 1
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
  3. Blackberry Bold 9000 Antenna Replacement: step 3, image 1 of 1
    • From the top, use your fingernail to lift the battery out.
  4. Blackberry Bold 9000 Antenna Replacement, Rear Case: step 4, image 1 of 1
    • Remove the SIM card.
  5. Blackberry Bold 9000 Antenna Replacement: step 5, image 1 of 1
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
  6. Blackberry Bold 9000 Antenna Replacement: step 6, image 1 of 1
    • Use the plastic opening tool to remove the rear case.
  7. Blackberry Bold 9000 Antenna Replacement, Antenna: step 7, image 1 of 1
    • The two antennas are built into the rear case. Replace this piece to replace the antenna.
2 other people completed this guide.
Jacob
125 Reputation
1 Guide authored
Cal Poly, Team 8-17, Maness Winter 2012 Member of Cal Poly, Team 8-17, Maness Winter 2012
CPSU-MANESS-W12S8G17
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 5
All Time: 5,178
