Blackberry Bold 9000 Rear Case Replacement
  1. Blackberry Bold 9000 Rear Case Replacement, Battery: step 1, image 1 of 1
    • Place your Blackberry facedown in front of you.
  2. Blackberry Bold 9000 Rear Case Replacement: step 2, image 1 of 1
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
  3. Blackberry Bold 9000 Rear Case Replacement: step 3, image 1 of 1
    • From the top, use your fingernail to lift the battery out.
  4. Blackberry Bold 9000 Rear Case Replacement, Rear Case: step 4, image 1 of 1
    • Remove the SIM card.
  5. Blackberry Bold 9000 Rear Case Replacement: step 5, image 1 of 1
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
  6. Blackberry Bold 9000 Rear Case Replacement: step 6, image 1 of 1
    • Use the plastic opening tool to remove the rear case.
2 other people completed this guide.
Kelly
566 Reputation
6 Guides authored
Cal Poly, Team 8-17, Maness Winter 2012 Member of Cal Poly, Team 8-17, Maness Winter 2012
CPSU-MANESS-W12S8G17
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 3,223
