Blackberry Bold 9650 Faceplate Replacement
  1. Blackberry Bold 9650 Faceplate Replacement, Battery: step 1, image 1 of 2 Blackberry Bold 9650 Faceplate Replacement, Battery: step 1, image 2 of 2
    • Turn the device upside down.
    • Using your finger, slide the silver cover release button towards the top of the device.
    • Lift and remove the back cover.
  2. Blackberry Bold 9650 Faceplate Replacement: step 2, image 1 of 1
    • Using your fingernails, lift the sides of the battery.
    • Remove the battery.
  3. Blackberry Bold 9650 Faceplate Replacement, SIM Card: step 3, image 1 of 1
    • Orient the device so that the screen is facing the ground.
    • Using your finger, gently lift the top of the SIM card.
  4. Blackberry Bold 9650 Faceplate Replacement: step 4, image 1 of 1
    • Gently pull out the SIM card.
    • The card will break in half if you apply too much force when pulling out the card.
  5. Blackberry Bold 9650 Faceplate Replacement, Back Chassis: step 5, image 1 of 1
    • Using a T6 Torx screwdriver, remove the four screws from the bottom half of the device.
  6. Blackberry Bold 9650 Faceplate Replacement: step 6, image 1 of 1
    • Orient the device so that the screen is facing you.
    • Using a spudger, remove the ear piece cover.
  7. Blackberry Bold 9650 Faceplate Replacement: step 7, image 1 of 1
    • Using a T6 Torx screwdriver, remove the two screws from the top corners of the device.
  8. Blackberry Bold 9650 Faceplate Replacement: step 8, image 1 of 1
    • Remove the back chassis by gently pulling the chassis back and forth.
    • The headphone jack can break if the chassis is pulled too forcefully.
  9. Blackberry Bold 9650 Faceplate Replacement, Mother Board: step 9, image 1 of 1
    Tool used on this step:
    Buy
    • Orient the device so that the screen is facing the ground, and the top of the phone is facing you.
    • Using a pair of tweezers, lift and remove the following:
    • The two round connectors on the top of the mother board.
    • The round connectors are hooked into the mother board.
    • The flat connector in the lower corner of the mother board.
  10. Blackberry Bold 9650 Faceplate Replacement: step 10, image 1 of 1
    • Using your fingers, carefully lift and remove the mother board.
    • The connectors underneath the mother board are delicate and easily damaged.
  11. Blackberry Bold 9650 Faceplate Replacement: step 11, image 1 of 1
    • Using a pair of tweezers, remove the three ribbon connectors.
  12. Blackberry Bold 9650 Faceplate Replacement: step 12, image 1 of 1
    • Remove the mother board by lifting the board upward.
  13. Blackberry Bold 9650 Faceplate Replacement, Faceplate: step 13, image 1 of 2 Blackberry Bold 9650 Faceplate Replacement, Faceplate: step 13, image 2 of 2
    • Using a pry tool, lift up on the four tabs located on the edges of the faceplate.
    • Remove the faceplate by lifting the plate upward.
2 other people completed this guide.
Ryan
696 Reputation
11 Guides authored
Clemson, Team 2-5, Benson Spring 2012 Member of Clemson, Team 2-5, Benson Spring 2012
CLEM-BENSON-S12S2G5
2 Members
14 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 9
All Time: 2,412
