Blackberry Bold 9900 Keyboard Replacement
  1. Blackberry Bold 9900 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Place phone screen down.
    • Use your finger to life upward on the battery case.
    • Pull the cover away from the battery.
  2. Blackberry Bold 9900 Keyboard Replacement: step 2, image 1 of 1
    • Lift the edge of battery with the green stripe upward to remove battery.
  3. Blackberry Bold 9900 Keyboard Replacement, MicroSD card: step 3, image 1 of 2 Blackberry Bold 9900 Keyboard Replacement, MicroSD card: step 3, image 2 of 2
    • The MicroSD card is located where the red rectangle is shown.
    • To remove MicroSD card, push the card inward towards the top of the phone then release. The MicroSD card will be ejected.
  4. Blackberry Bold 9900 Keyboard Replacement, Keyboard: step 4, image 1 of 2 Blackberry Bold 9900 Keyboard Replacement, Keyboard: step 4, image 2 of 2
    • Lift the bezel at the bottom of the phone up and peel it away from the phone.
  5. Blackberry Bold 9900 Keyboard Replacement: step 5, image 1 of 2 Blackberry Bold 9900 Keyboard Replacement: step 5, image 2 of 2
    • Remove the two exposed screws using the T5 Torx screwdriver.
  6. Blackberry Bold 9900 Keyboard Replacement: step 6, image 1 of 1
    • Now lever the keyboard up using the screwdriver in the indicated hole.
  7. Blackberry Bold 9900 Keyboard Replacement: step 7, image 1 of 2 Blackberry Bold 9900 Keyboard Replacement: step 7, image 2 of 2
    • The keyboard is attached via a ribbon cable. Pull the cable up to remove the keyboard.
Chris Velasquez
214 Reputation
2 Guides authored
Baylor, Team S1-G4, Johnson Spring 2018 Member of Baylor, Team S1-G4, Johnson Spring 2018
BU-JOHNSON-S18S1G4
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 14
All Time: 1,567
