Blackberry Bold 9900 Screen Replacement
    1. Blackberry Bold 9900 Screen Replacement, Battery: step 1, image 1 of 1
      • Place phone screen down.
      • Use your finger to life upward on the battery case.
      • Pull the cover away from the battery.
      Ask FixBot
    2. Blackberry Bold 9900 Screen Replacement: step 2, image 1 of 1
      • Lift the edge of battery with the green stripe upward to remove battery.
      Ask FixBot
    1. Blackberry Bold 9900 Screen Replacement, Mini-SIM removal: step 3, image 1 of 1
      • The Mini-SIM card is located inside the red rectangle.
      • To remove the Mini-SIM Card, push and slide the card inward towards the top of the phone. It will be ejected.
      Ask FixBot
    1. Blackberry Bold 9900 Screen Replacement, MicroSD card: step 4, image 1 of 2 Blackberry Bold 9900 Screen Replacement, MicroSD card: step 4, image 2 of 2
      • The MicroSD card is located where the red rectangle is shown.
      • To remove MicroSD card, push the card inward towards the top of the phone then release. The MicroSD card will be ejected.
      Ask FixBot
    1. Blackberry Bold 9900 Screen Replacement, Keyboard: step 5, image 1 of 2 Blackberry Bold 9900 Screen Replacement, Keyboard: step 5, image 2 of 2
      • Lift the bezel at the bottom of the phone up and peel it away from the phone.
      Ask FixBot
    2. Blackberry Bold 9900 Screen Replacement: step 6, image 1 of 2 Blackberry Bold 9900 Screen Replacement: step 6, image 2 of 2
      • Remove the two exposed screws using the T5 Torx screwdriver.
      Ask FixBot
    3. Blackberry Bold 9900 Screen Replacement: step 7, image 1 of 1
      • Now lever the keyboard up using the screwdriver in the indicated hole.
      Ask FixBot
    4. Blackberry Bold 9900 Screen Replacement: step 8, image 1 of 2 Blackberry Bold 9900 Screen Replacement: step 8, image 2 of 2
      • The keyboard is attached via a ribbon cable. Pull the cable up to remove the keyboard.
      Ask FixBot
    1. Blackberry Bold 9900 Screen Replacement, Back Case: step 9, image 1 of 1
      • Using the T5 Torx Screwdriver, remove the four torx screws that are located on the bottom half of the device
      Ask FixBot
    2. Blackberry Bold 9900 Screen Replacement: step 10, image 1 of 1
      • Now, carefully and gently using your fingers, lift and remove the assembly from the back case.
      Ask FixBot
    1. Blackberry Bold 9900 Screen Replacement, Power/Volume Button: step 11, image 1 of 3 Blackberry Bold 9900 Screen Replacement, Power/Volume Button: step 11, image 2 of 3 Blackberry Bold 9900 Screen Replacement, Power/Volume Button: step 11, image 3 of 3
      • Use the black nylon spudger to pop the press fit connector up from the lower left corner of the motherboard.
      Ask FixBot
    2. Blackberry Bold 9900 Screen Replacement: step 12, image 1 of 1
      • Lift the midframe, which contains the power/volume buttons, off of the motherboard and screen.
      Ask FixBot
    1. Blackberry Bold 9900 Screen Replacement, Screen: step 13, image 1 of 3 Blackberry Bold 9900 Screen Replacement, Screen: step 13, image 2 of 3 Blackberry Bold 9900 Screen Replacement, Screen: step 13, image 3 of 3
      • Using a spudger, gently remove the display cable out from the motherboard.
      • When it seems it has become loose enough, remove it by pinching the ribbon firmly with your fingers and gently sliding it the rest of the way out.
      Ask FixBot
    2. Blackberry Bold 9900 Screen Replacement: step 14, image 1 of 1
      • Remove the screen from the motherboard.
      Ask FixBot
Austin Blakely
23,282 Reputation
53 Guides authored
iFixit Member of iFixit
Staff
122 Members
86,241 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 50
All Time: 2,145
