Blackberry Curve 9300 SIM Card Replacement
  1. Blackberry Curve 9300 SIM Card Replacement, Battery: step 1, image 1 of 1
    • Place your Blackberry face down in front of you.
  2. Blackberry Curve 9300 SIM Card Replacement: step 2, image 1 of 1
    • Locate the indent on the bottom of the back cover.
    • Use your fingernail to lift and remove the back cover.
  3. Blackberry Curve 9300 SIM Card Replacement: step 3, image 1 of 1
    • From the top, use your fingernail to lift and remove the battery.
  4. Blackberry Curve 9300 SIM Card Replacement, SIM Card: step 4, image 1 of 1
    • Make sure phone is face down with the battery removed.
  5. Blackberry Curve 9300 SIM Card Replacement: step 5, image 1 of 1
    • Place thumb on bottom of SIM card. Apply light pressure and slide SIM card up.
  6. Blackberry Curve 9300 SIM Card Replacement: step 6, image 1 of 2 Blackberry Curve 9300 SIM Card Replacement: step 6, image 2 of 2
    • Lift up and remove.
Rory Stothers
545 Reputation
2 Guides authored
Cal Poly, Team 14-7, Forte Fall 2013 Member of Cal Poly, Team 14-7, Forte Fall 2013
CPSU-FORTE-F13S14G7
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 2,482
