Blackberry PRIV Volume Buttons Replacement
  1. Blackberry PRIV Volume Buttons Replacement, Rear Casing: step 1, image 1 of 3 Blackberry PRIV Volume Buttons Replacement, Rear Casing: step 1, image 2 of 3 Blackberry PRIV Volume Buttons Replacement, Rear Casing: step 1, image 3 of 3
    • Look for the two small holes at the top of your device.
    • Use a SIM eject tool to push down into the holes which lifts the SIM and SD trays.
    • Pull the trays up and out of the device.
  2. Blackberry PRIV Volume Buttons Replacement: step 2, image 1 of 3 Blackberry PRIV Volume Buttons Replacement: step 2, image 2 of 3 Blackberry PRIV Volume Buttons Replacement: step 2, image 3 of 3
    • Insert an opening pick in the seam between the rear casing and chassis. Apply downward pressure to pry the casing upward.
    • Follow this procedure for only the right, left, and top side of the casing.
  3. Blackberry PRIV Volume Buttons Replacement: step 3, image 1 of 3 Blackberry PRIV Volume Buttons Replacement: step 3, image 2 of 3 Blackberry PRIV Volume Buttons Replacement: step 3, image 3 of 3
    • Remove the rear casing by sliding the case down and out.
  4. Blackberry PRIV Volume Buttons Replacement, Volume Buttons: step 4, image 1 of 3 Blackberry PRIV Volume Buttons Replacement, Volume Buttons: step 4, image 2 of 3 Blackberry PRIV Volume Buttons Replacement, Volume Buttons: step 4, image 3 of 3
    • Locate the volume buttons which are on the right side of inside the rear casing.
    • Using your SIM eject tool push the volume button out of plastic prong.
    • Push the other side of the volume button.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Benjamin Olvera
563 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 206
