Blackberry RIM 7250 Back Housing Replacement
  1. Blackberry RIM 7250 Back Housing Replacement, Battery: step 1, image 1 of 3 Blackberry RIM 7250 Back Housing Replacement, Battery: step 1, image 2 of 3 Blackberry RIM 7250 Back Housing Replacement, Battery: step 1, image 3 of 3
    • Push the release button down and away from the device.
    • Slide the cover off toward the bottom of the device, revealing the battery compartment.
  2. Blackberry RIM 7250 Back Housing Replacement: step 2, image 1 of 3 Blackberry RIM 7250 Back Housing Replacement: step 2, image 2 of 3 Blackberry RIM 7250 Back Housing Replacement: step 2, image 3 of 3
    • Place your finger in the groove next to the battery.
    • Lift your finger up to eject the battery from the battery compartment.
  3. Blackberry RIM 7250 Back Housing Replacement: step 3, image 1 of 3 Blackberry RIM 7250 Back Housing Replacement: step 3, image 2 of 3 Blackberry RIM 7250 Back Housing Replacement: step 3, image 3 of 3
    • Remove the battery from the compartment.
  4. Blackberry RIM 7250 Back Housing Replacement, Back Housing: step 4, image 1 of 2 Blackberry RIM 7250 Back Housing Replacement, Back Housing: step 4, image 2 of 2
    • Remove the four 10.7 mm Torx T6 screws.
  5. Blackberry RIM 7250 Back Housing Replacement: step 5, image 1 of 2 Blackberry RIM 7250 Back Housing Replacement: step 5, image 2 of 2
    • Remove the two 5 mm Torx T6 screws.
  6. Blackberry RIM 7250 Back Housing Replacement: step 6, image 1 of 1
    • Hold the phone with one hand, with the bottom facing toward you.
    • For both clips, insert the plastic opening tool and push away from you.
    • You will hear a clicking sound for each clip that is released.
  7. Blackberry RIM 7250 Back Housing Replacement: step 7, image 1 of 3 Blackberry RIM 7250 Back Housing Replacement: step 7, image 2 of 3 Blackberry RIM 7250 Back Housing Replacement: step 7, image 3 of 3
    • Grab the back housing from the bottom and lift the housing away from you.
Noah Eckert
519 Reputation
5 Guides authored
IUPUI, Team S2-G4, Baechle Fall 2018 Member of IUPUI, Team S2-G4, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G4
3 Members
5 Guides authored
One Comment
Great Guide!
Suketu Patel - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 193
