Blackberry Storm 9530 Battery Replacement
  1. Blackberry Storm 9530 Battery Replacement, Back Cover Removal: step 1, image 1 of 3 Blackberry Storm 9530 Battery Replacement, Back Cover Removal: step 1, image 2 of 3 Blackberry Storm 9530 Battery Replacement, Back Cover Removal: step 1, image 3 of 3
    • Locate the two switches toward the bottom corners of the device's back cover.
    • Use your thumbs or fingers to push the two switches forward at the same time and detach the back cover from the device.
    • Check to make sure the back cover has fully detached from the device. You should be left with two separate pieces: the back cover, and the device with exposed internal hardware.
  2. Blackberry Storm 9530 Battery Replacement: step 2, image 1 of 1
    • Identify that the battery is visible once the back cover has been removed, and locate the battery in the rectangular-shaped top half of the device.
    • Pry apart the battery and back of the device using the flat end of your spudger tool or using your finger if you do not have a spudger.
    • Your battery has a specific orientation resembling a horizontal rectangle. Make sure the gold colored leads are aligned with the gold colored strips on your battery before reassembling.
melanie lim
607 Reputation
6 Guides authored
Cal Poly, Team 9-16, Regan Spring 2014 Member of Cal Poly, Team 9-16, Regan Spring 2014
CPSU-REGAN-S14S9G16
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 17
All Time: 1,678
