Blackberry Torch 9800 Logic Board Replacement
  1. Blackberry Torch 9800 Logic Board Replacement, Logic Board Replacement: step 1, image 1 of 2 Blackberry Torch 9800 Logic Board Replacement, Logic Board Replacement: step 1, image 2 of 2
    • Remove the back cover and the battery.
    • Unscrew the four screws using a T6 screwdriver.
    • Removing the top right screw (with the blue cover) will void the warranty.
  2. Blackberry Torch 9800 Logic Board Replacement: step 2, image 1 of 2 Blackberry Torch 9800 Logic Board Replacement: step 2, image 2 of 2
    • Remove the side trim using the plastic opening tool.
    • Apply pressure to push the top side of the side trim towards the phone while pulling the bottom away from the phone to remove the side trim.
    • The side trim is fragile and easily fractured, so handful it with care.
  3. Blackberry Torch 9800 Logic Board Replacement: step 3, image 1 of 3 Blackberry Torch 9800 Logic Board Replacement: step 3, image 2 of 3 Blackberry Torch 9800 Logic Board Replacement: step 3, image 3 of 3
    • Remove the two screws that have been revealed at the top of the device using the T6 screwdriver.
    • You should now be able to easily lift the back panel from the phone.
  4. Blackberry Torch 9800 Logic Board Replacement: step 4, image 1 of 2 Blackberry Torch 9800 Logic Board Replacement: step 4, image 2 of 2
    • Using your hands, carefully peel the three ribbon cable caps from the logic board.
  5. Blackberry Torch 9800 Logic Board Replacement: step 5, image 1 of 2 Blackberry Torch 9800 Logic Board Replacement: step 5, image 2 of 2
    • Lift logic board slightly. The logic board will remain attached to the phone by a small antenna wire.
    • Using your hands, carefully lift the clasp attached to the antenna wire straight upward away from the logic board.
    • Make sure not to disconnect the antenna wire from its clasp.
    • The logic board should now be completely separate from the phone.
3 other people completed this guide.
Keegan Williams
216 Reputation
2 Guides authored
Ohio State, Team 1-5, Garvin Spring 2016 Member of Ohio State, Team 1-5, Garvin Spring 2016
OSU-GARVIN-S16S1G5
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 878
