Blackberry Torch 9800 Replacing rear camera
  1. Blackberry Torch 9800 Replacing rear camera, Replacing rear camera: step 1, image 1 of 2 Blackberry Torch 9800 Replacing rear camera, Replacing rear camera: step 1, image 2 of 2
    • Remove the back cover and the battery.
    • Remove the four exposed screws using a T7 screwdriver.
    • Warning: Removing the top right screw (with the blue cover) will void the warranty.
  2. Blackberry Torch 9800 Replacing rear camera: step 2, image 1 of 2 Blackberry Torch 9800 Replacing rear camera: step 2, image 2 of 2
    • Remove the side trim using the plastic opening tool.
    • When loose, push the top backwards and the bottom forwards to remove.
  3. Blackberry Torch 9800 Replacing rear camera: step 3, image 1 of 3 Blackberry Torch 9800 Replacing rear camera: step 3, image 2 of 3 Blackberry Torch 9800 Replacing rear camera: step 3, image 3 of 3
    • Two new screws have been exposed near the top of the back.
    • Remove the two screws using the T7 screwdriver.
    • Remove the back panel using the plastic opening tool.
  4. Blackberry Torch 9800 Replacing rear camera: step 4, image 1 of 2 Blackberry Torch 9800 Replacing rear camera: step 4, image 2 of 2
    • Carefully use flathead screwdriver to free camera sensor.
    • Wiggle on the right and left sides, not the top and bottom sides.
  5. Blackberry Torch 9800 Replacing rear camera: step 5, image 1 of 1
    • To install the new camera sensor, place in slot. Reassemble phone by doing steps 1-3 in reverse order.
0delete
183 Reputation
1 Guide authored
Ohio State, Team 1-5, Garvin Spring 2016 Member of Ohio State, Team 1-5, Garvin Spring 2016
OSU-GARVIN-S16S1G5
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 283
