Blackberry Torch 9810 Cursor Key Replacement
  1. Blackberry Torch 9810 Cursor Key Replacement, Phone cover: step 1, image 1 of 2 Blackberry Torch 9810 Cursor Key Replacement, Phone cover: step 1, image 2 of 2
    • Remove the back cover of the phone
  2. Blackberry Torch 9810 Cursor Key Replacement, Battery: step 2, image 1 of 1
    • Remove the battery
  3. Blackberry Torch 9810 Cursor Key Replacement, Remove screws: step 3, image 1 of 1
    • Unscrew the four screws using the T6 screw driver.
    • If you remove the screw in red, you void the warranty!
  4. Blackberry Torch 9810 Cursor Key Replacement, Wiggle Wiggle: step 4, image 1 of 2 Blackberry Torch 9810 Cursor Key Replacement, Wiggle Wiggle: step 4, image 2 of 2
    • Slide the screen up.
    • Remove front silver trim by using a plastic opening tools and wiggle it off.
    • This is difficult to remove, but it should come off if you do it with caution.
  5. Blackberry Torch 9810 Cursor Key Replacement, More screws that need to go: step 5, image 1 of 1
    • Once you remove the rim cover, you should find two more screws on the top. Unscrew them with a T-6 screw driver.
  6. Blackberry Torch 9810 Cursor Key Replacement, Remove the Back: step 6, image 1 of 3 Blackberry Torch 9810 Cursor Key Replacement, Remove the Back: step 6, image 2 of 3 Blackberry Torch 9810 Cursor Key Replacement, Remove the Back: step 6, image 3 of 3
    • Use the plastic opening tools to remove the entire back off the phone.
  7. Blackberry Torch 9810 Cursor Key Replacement, Remove Ribbon Cables: step 7, image 1 of 1
    • Remove the three ribbon cables and the antenna wire by hand.
    • The cable in red is glued to the metal cap. Peel it upwards towards the battery compartment.
  8. Blackberry Torch 9810 Cursor Key Replacement, Remove Logic Board: step 8, image 1 of 1
    • The logic board will easily pull straight out.
  9. Blackberry Torch 9810 Cursor Key Replacement, Remove Informational Sticker: step 9, image 1 of 1
    • Remove the black sticker located above the logic board that contains the phone's serial number
  10. Blackberry Torch 9810 Cursor Key Replacement, Remove More Screws: step 10, image 1 of 1
    • Behind the black sticker you should find six small yellow screws. Remove them with a T4 torx screwdriver.
  11. Blackberry Torch 9810 Cursor Key Replacement, Separate the phone: step 11, image 1 of 1
    • Carefully separate the screen from the body.
    • Make sure to be extra careful with the ribbon!
  12. Blackberry Torch 9810 Cursor Key Replacement: step 12, image 1 of 1
    • Slide the silver plate up and you should find four more screws that need to be removed. Use a T-4 screw driver.
    • They are on a black cover located on the bottom of the phone. The black cover will come off
  13. Blackberry Torch 9810 Cursor Key Replacement, Carefully Remove a Ribbion: step 13, image 1 of 1
    • There is one last orange ribbon cable that needs to be pulled and behind it is the cursor
  14. Blackberry Torch 9810 Cursor Key Replacement, Cursor Key: step 14, image 1 of 3 Blackberry Torch 9810 Cursor Key Replacement, Cursor Key: step 14, image 2 of 3 Blackberry Torch 9810 Cursor Key Replacement, Cursor Key: step 14, image 3 of 3
    • Push the cursor upwards and out of the socket.
    • Gently pull out the white box by pulling straight out of the socket to the right. This is your cursor
Jocelyn Adorno
296 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 1,482
