Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement
  1. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement, Fan: step 1, image 1 of 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement, Fan: step 1, image 2 of 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement, Fan: step 1, image 3 of 3
    • Make sure the diffuser is not plugged into a socket and that there is no water or oil near or in the diffuser before beginning the guide.
    • Use a Phillips #2 screwdriver to remove the four 8 mm screws on the bottom of the diffuser.
  2. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: step 2, image 1 of 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: step 2, image 2 of 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: step 2, image 3 of 3
    • Lift the ceramic top of the oil diffuser.
    • Then lift off the plastic top off the diffuser.
  3. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: step 3, image 1 of 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: step 3, image 2 of 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: step 3, image 3 of 3
    • Lift the last plastic lid.
    • You will see a circuit board, and there will be a cord connecting it to the circuit board.
  4. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: step 4, image 1 of 2 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: step 4, image 2 of 2
    • Gently unplug the cord from the circuit board.
    • Place the plastic lid somewhere safe on the a flat surface.
  5. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: step 5, image 1 of 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: step 5, image 2 of 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: step 5, image 3 of 3
    • Remove the plastic ring and place somewhere safe on a flat surface.
  6. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: step 6, image 1 of 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: step 6, image 2 of 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: step 6, image 3 of 3
    • Remove two Truss head 4 mm screws with a Phillips #2 screwdriver and place safely nearby.
  7. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: step 7, image 1 of 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: step 7, image 2 of 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: step 7, image 3 of 3
    • Gently lift the circuit board onto it's side
    • The white connector plugs the fan into the circuit board.
  8. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: step 8, image 1 of 2 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: step 8, image 2 of 2
    • Unplug the white connector.
    • There are four #M1 6 mm Phillips pan head screws holding down the fan.
  9. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: step 9, image 1 of 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: step 9, image 2 of 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: step 9, image 3 of 3
    • Remove the #M1 6 mm screws with a Phillips #2 screwdriver while holding down the fan.
    • Gently lift the fan and place the fan someplace safe on the flat surface.
Muniira Mohamoud
169 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 24
All Time: 379
