Blu Dash 5.0 Dual SIM Battery Replacement
  1. Blu Dash 5.0 Dual SIM Battery Replacement, Battery: step 1, image 1 of 1
    • Find the small slot on the bottom left corner of the back panel.
    • Slide the spudger into the small slot and lightly twist it. This will cause the corner of the back panel to pop up.
    • When the back panel is loose enough, use your fingers to remove it completely.
  2. Blu Dash 5.0 Dual SIM Battery Replacement: step 2, image 1 of 1
    • With the back panel off, you should see a large white rectangle. This is the battery. Slide the spudger under the indent on the bottom right of the battery and pull it up.
5 other people completed this guide.
Dashaya Toney
876 Reputation
3 Guides authored
UMass Dartmouth, Team 4-7, Miles Fall 2014 Member of UMass Dartmouth, Team 4-7, Miles Fall 2014
UMASSD-MILES-F14S4G7
3 Members
3 Guides authored
One Comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 4,078
