Blu Grand M Display Replacement
  1. Blu Grand M Display Replacement, Display: step 1, image 1 of 1
    • Trace the outer black edge of the phone screen in a continuous circle with a hairdryer or heat gun to melt the adhesive.
    • Melting the adhesive can take between 2-3 minutes.
  2. Blu Grand M Display Replacement: step 2, image 1 of 3 Blu Grand M Display Replacement: step 2, image 2 of 3 Blu Grand M Display Replacement: step 2, image 3 of 3
    Tool used on this step:
    Halberd Spudger
    $2.99
    Buy
    • Insert an opening pick between the screen and the raised black plastic frame.
    • The black plastic frame is located inside and above the phone's silvery outer metal frame.
    • Insert the flat blade of a nylon halberd spudger between the screen and the black plastic frame.
    • Pull the spudger blade through the adhesive around the circumference of the screen.
  3. Blu Grand M Display Replacement: step 3, image 1 of 3 Blu Grand M Display Replacement: step 3, image 2 of 3 Blu Grand M Display Replacement: step 3, image 3 of 3
    • Apply the suction cup to the phone screen, pressing lightly on the suction cup to remove air and form a tight seal.
    • The adhesive may have cooled from the time since step 1 and rebonded to the phone screen. Reheat the adhesive if necessary to return to a liquid state.
    • Pull on the handle to lift the screen free from the device.
Finish Line
Liam Rollins
253 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 10
All Time: 333
