Blu Grand M Speaker Replacement
  1. Blu Grand M Speaker Replacement, Battery: step 1, image 1 of 2 Blu Grand M Speaker Replacement, Battery: step 1, image 2 of 2
    • Remove the two plastic plates with a plastic opening tool.
  2. Blu Grand M Speaker Replacement: step 2, image 1 of 1
    • Using a Phillips #000 screwdriver, remove the 3mm screws. Be sure to do this for the top and bottom of the phone.
  3. Blu Grand M Speaker Replacement: step 3, image 1 of 3 Blu Grand M Speaker Replacement: step 3, image 2 of 3 Blu Grand M Speaker Replacement: step 3, image 3 of 3
    • Remove SIM card tray with paperclip or SIM card tray removal tool.
    • Push down on the phone beside the camera and up on the backplate with your thumbs to remove the back plate. Remove adhesive if necessary.
  4. Blu Grand M Speaker Replacement: step 4, image 1 of 2 Blu Grand M Speaker Replacement: step 4, image 2 of 2
    • There is a patch of adhesive underneath the battery, which can make it difficult to remove.
    • Place the plastic opening tool in the highlighted indent, and push up on the battery to remove it.
  5. Blu Grand M Speaker Replacement, Speaker: step 5, image 1 of 2 Blu Grand M Speaker Replacement, Speaker: step 5, image 2 of 2
    • Remove the exterior cover with a Torx 2 screwdriver, to remove two 3.0mm screws.
    • Remove the 4.0mm screw with a Phillips #000 screwdriver.
    • Using the blue plastic opening tool, remove the exterior cover.
  6. Blu Grand M Speaker Replacement: step 6, image 1 of 3 Blu Grand M Speaker Replacement: step 6, image 2 of 3 Blu Grand M Speaker Replacement: step 6, image 3 of 3
    • Use a Phillips #000 screwdriver to remove each of the four 1.5mm screws.
    • Use a Phillips #000 screwdriver to remove each of the three 3.0mm screws.
    • Use the plastic opening tool to remove the speaker.
Cameron Retzlaff
608 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 117
