Blu Grand M2 Display Replacement
  1. Blu Grand M2 Display Replacement, Display: step 1, image 1 of 2 Blu Grand M2 Display Replacement, Display: step 1, image 2 of 2
    • Before beginning the guide, be sure that this replacement guide addresses your specific problem.
    • Locate the two Torx screws at the bottom of the phone and remove them.
  2. Blu Grand M2 Display Replacement: step 2, image 1 of 1
    • Use the pry tool to wedge between the phone's frame and the back plate.
    • Carefully remove the back plate using the suction tool.
    • Be careful not to damage the phone display and/or the inside components while using the pry tool and the suction tool.
  3. Blu Grand M2 Display Replacement: step 3, image 1 of 3 Blu Grand M2 Display Replacement: step 3, image 2 of 3 Blu Grand M2 Display Replacement: step 3, image 3 of 3
    • Once the back panel is removed, locate the connector of the display shown in figure 1 on the motherboard side.
    • There will be an orange sticker above the previously mentioned connector. You can gently lift the connector up to release it.
    • Disconnect the two remaining connectors shown in figure 3.
  4. Blu Grand M2 Display Replacement: step 4, image 1 of 2 Blu Grand M2 Display Replacement: step 4, image 2 of 2
    • After removing the connectors, locate the six Phillips screws on the motherboard side and remove them.
    • After removing the six Phillips screws, remove the motherboard piece.
  5. Blu Grand M2 Display Replacement: step 5, image 1 of 1
    • Once you have removed the motherboard piece, flip the phone so the screen is facing up and begin using the iOpener.
    • Heat up the iOpener from the iFixit kit for 30 seconds in a microwave and apply it on top of the screen to loosen the phone's adhesive.
    • The iOpener can be hot once it is microwaved. Make sure to wear gloves and other safety equipment to prevent any burns.
  6. Blu Grand M2 Display Replacement: step 6, image 1 of 3 Blu Grand M2 Display Replacement: step 6, image 2 of 3 Blu Grand M2 Display Replacement: step 6, image 3 of 3
    • Using the suction tool, slowly pull out the display screen shown in figure 1.
    • Use the pry tool to completely detach the display screen from the phone.
    • When the display is removed, attach your new screen.
    • After applying the new screen, use the steps in reverse order to reassemble the phone.
Christopher
192 Reputation
1 Guide authored
Gateway, Team S1-G3, Luster Fall 2018 Member of Gateway, Team S1-G3, Luster Fall 2018
GCC-LUSTER-F18S1G3
4 Members
4 Guides authored
1 Guide Comment
What type of torx screwdriver did you use?
npyles86 - Reply
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 31
All Time: 1,962
