Blu L120 Screen Assembly Replacement
  1. Blu L120 Screen Assembly Replacement, Remove back panel: step 1, image 1 of 3 Blu L120 Screen Assembly Replacement, Remove back panel: step 1, image 2 of 3 Blu L120 Screen Assembly Replacement, Remove back panel: step 1, image 3 of 3
    • Remove the cover by lifting the notch towards the bottom of the phone. Use your fingernail to lift it up.
  2. Blu L120 Screen Assembly Replacement, Screw Removal: step 2, image 1 of 3 Blu L120 Screen Assembly Replacement, Screw Removal: step 2, image 2 of 3 Blu L120 Screen Assembly Replacement, Screw Removal: step 2, image 3 of 3
    • Remove these nine screws with a small phillips screwdriver. They are all the same size.
    • There is a small screw hidden under the warranty sticker. You may either remove or poke through it .
  3. Blu L120 Screen Assembly Replacement, Rear Panel  removal: step 3, image 1 of 3 Blu L120 Screen Assembly Replacement, Rear Panel  removal: step 3, image 2 of 3 Blu L120 Screen Assembly Replacement, Rear Panel  removal: step 3, image 3 of 3
    • Use the pry tool to gently separate the panel from the frame, starting from the bottom left corner and continue along the edge of the phone.
    • *WARNING* by doing this, you will void the manufacturers warranty.
  4. Blu L120 Screen Assembly Replacement, Separate back panel from frame: step 4, image 1 of 3 Blu L120 Screen Assembly Replacement, Separate back panel from frame: step 4, image 2 of 3 Blu L120 Screen Assembly Replacement, Separate back panel from frame: step 4, image 3 of 3
    • Continue using the pry tool around the back panel of the phone to separate both pieces.
    • Once you have gone around the entire frame, use both hands to pull it apart.
  5. Blu L120 Screen Assembly Replacement, Camera Removal: step 5, image 1 of 3 Blu L120 Screen Assembly Replacement, Camera Removal: step 5, image 2 of 3 Blu L120 Screen Assembly Replacement, Camera Removal: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Use the pry tool to disconnect the camera from the device.
    • Gently lift the camera up and use the tweezers to remove it from the phone.
    • Reinstall the camera. Then follow the guide in reverse to put the phone back together.
  6. Blu L120 Screen Assembly Replacement, Motherboard: step 6, image 1 of 3 Blu L120 Screen Assembly Replacement, Motherboard: step 6, image 2 of 3 Blu L120 Screen Assembly Replacement, Motherboard: step 6, image 3 of 3
    • Remove these three screws using 00 Philips screwdriver. Note the smaller screw circled in orange.
    • Then gently pry up on the metal antenna connector at the end of the grey wire. Move the wire out of the way.
  7. Blu L120 Screen Assembly Replacement: step 7, image 1 of 2 Blu L120 Screen Assembly Replacement: step 7, image 2 of 2
    • Next you must disconnect these three cables.
    • Use your pry tool to lift up on the brown tab to release the ribbon cable.
  8. Blu L120 Screen Assembly Replacement: step 8, image 1 of 3 Blu L120 Screen Assembly Replacement: step 8, image 2 of 3 Blu L120 Screen Assembly Replacement: step 8, image 3 of 3
    • For the last ribbon cable, use a spudger to gently pry up on the board under the right sim card slot.
    • Next, take your pry tool to lift up on the brown tab holding down the ribbon cable.
    • The cable is now free to be pulled back out of its' slot.
  9. Blu L120 Screen Assembly Replacement: step 9, image 1 of 3 Blu L120 Screen Assembly Replacement: step 9, image 2 of 3 Blu L120 Screen Assembly Replacement: step 9, image 3 of 3
    Buy
    • Using a spudger, peel up on the mesh tape then use your tweezers to peel the rest of it up.
  10. Blu L120 Screen Assembly Replacement: step 10, image 1 of 3 Blu L120 Screen Assembly Replacement: step 10, image 2 of 3 Blu L120 Screen Assembly Replacement: step 10, image 3 of 3
    • Now that the motherboard is free to be pried up, be sure that no cables are in the way or can be snagged when removing the motherboard.
    • Just lift up and away.
    • Follow the instructions in reverse to put the phone back together.
  11. Blu L120 Screen Assembly Replacement, Screen Assembly: step 11, image 1 of 2 Blu L120 Screen Assembly Replacement, Screen Assembly: step 11, image 2 of 2
    Buy
    • Using your tweezers, peel back the yellow film to free the cable from the screen.
  12. Blu L120 Screen Assembly Replacement: step 12, image 1 of 2 Blu L120 Screen Assembly Replacement: step 12, image 2 of 2
    • We used the iOpener tool, heated it up, and placed it on top of the phone for a few seconds to loosen up the glue.
  13. Blu L120 Screen Assembly Replacement: step 13, image 1 of 3 Blu L120 Screen Assembly Replacement: step 13, image 2 of 3 Blu L120 Screen Assembly Replacement: step 13, image 3 of 3
    • Once the screen has been heated and the glue is tacky, put a plastic opening tool between the glass screen and the frame. Start lifting the glass away around the whole frame.
  14. Blu L120 Screen Assembly Replacement: step 14, image 1 of 3 Blu L120 Screen Assembly Replacement: step 14, image 2 of 3 Blu L120 Screen Assembly Replacement: step 14, image 3 of 3
    • When finished separating the glass from the frame with the pry tool, grab both the frame and glass with both hands and separate both pieces. CAUTION, there is a ribbon cable that needs to be removed from the back of the phone before full separation.
    • As you can see, the LCD still needs a bit more work to come apart.
  15. Blu L120 Screen Assembly Replacement: step 15, image 1 of 3 Blu L120 Screen Assembly Replacement: step 15, image 2 of 3 Blu L120 Screen Assembly Replacement: step 15, image 3 of 3
    • Take a spudger and gently push the cable through the cutout on the frame to separate the glass.
  16. Blu L120 Screen Assembly Replacement: step 16, image 1 of 2 Blu L120 Screen Assembly Replacement: step 16, image 2 of 2
    • Congratulations! Your device is now ready for a new glass panel!
2 other people completed this guide.
Julio
695 Reputation
6 Guides authored
Gateway, Team 1-5, Johnson Fall 2014 Member of Gateway, Team 1-5, Johnson Fall 2014
GCC-JOHNSON-F14S1G5
3 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 17
All Time: 1,880
