Blu Studio 5.5 S Speaker Replacement
  1. Blu Studio 5.5 S Speaker Replacement, Back Casing: step 1, image 1 of 1
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Blu Studio 5.5 S Speaker Replacement, Applying Pressure: step 2, image 1 of 3 Blu Studio 5.5 S Speaker Replacement, Applying Pressure: step 2, image 2 of 3 Blu Studio 5.5 S Speaker Replacement, Applying Pressure: step 2, image 3 of 3
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
  3. Blu Studio 5.5 S Speaker Replacement, Battery: step 3, image 1 of 3 Blu Studio 5.5 S Speaker Replacement, Battery: step 3, image 2 of 3 Blu Studio 5.5 S Speaker Replacement, Battery: step 3, image 3 of 3
    • Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it.
    • Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
  4. Blu Studio 5.5 S Speaker Replacement, Midframe: step 4, image 1 of 3 Blu Studio 5.5 S Speaker Replacement, Midframe: step 4, image 2 of 3 Blu Studio 5.5 S Speaker Replacement, Midframe: step 4, image 3 of 3
    • The speaker is located behind the inner back case. Using a Phillips #0 screwdriver, unscrew the 10, 7mm screws.
    • Using the Phillips #00 screwdriver, unscrew the two, 10mm screws at the bottom.
  5. Blu Studio 5.5 S Speaker Replacement, Aesthetic Bottom Case: step 5, image 1 of 1
    • Apply pressure and pop off the bottom aesthetic case, being careful not to break it.
  6. Blu Studio 5.5 S Speaker Replacement: step 6, image 1 of 3 Blu Studio 5.5 S Speaker Replacement: step 6, image 2 of 3 Blu Studio 5.5 S Speaker Replacement: step 6, image 3 of 3
    • Use the Spudger to pop the inner back casing off. Do this by lightly raising the side of the battery housing, then sliding the Spudger around the case.
    • Pick up the inner back case and flip it over.
  7. Blu Studio 5.5 S Speaker Replacement, Speaker: step 7, image 1 of 3 Blu Studio 5.5 S Speaker Replacement, Speaker: step 7, image 2 of 3 Blu Studio 5.5 S Speaker Replacement, Speaker: step 7, image 3 of 3
    Tool used on this step:
    $3.99
    Buy
    • The speaker is located on the bottom of the back inner case. To remove it, use a pair of angled tweezers.
    • Use the tweezers to remove the speaker off of the casing.
    • Only put the tweezers in enough to gain leverage.
Cody Dyl
804 Reputation
5 Guides authored
UMass Dartmouth, Team 4-8, Miles Fall 2014 Member of UMass Dartmouth, Team 4-8, Miles Fall 2014
UMASSD-MILES-F14S4G8
2 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 1,205
