Blu Studio HD 6.0 Midframe Replacement
  1. Blu Studio HD 6.0 Midframe Replacement, Rear Case: step 1, image 1 of 1
    • Begin by making sure your Blu Studio is turned off.
  2. Blu Studio HD 6.0 Midframe Replacement, Back Panel.: step 2, image 1 of 2 Blu Studio HD 6.0 Midframe Replacement, Back Panel.: step 2, image 2 of 2
    • To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
  3. Blu Studio HD 6.0 Midframe Replacement: step 3, image 1 of 2 Blu Studio HD 6.0 Midframe Replacement: step 3, image 2 of 2
    • Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed.
    • Your rear panel should be placed nearby and in a safe location until you are finished with your task.
  4. Blu Studio HD 6.0 Midframe Replacement, Midframe: step 4, image 1 of 2 Blu Studio HD 6.0 Midframe Replacement, Midframe: step 4, image 2 of 2
    • With your back panel already removed from the previous guide you'll need to acquire a Philips head screw driver size (PH00)
  5. Blu Studio HD 6.0 Midframe Replacement: step 5, image 1 of 1
    • Next proceed to remove all 16 screws (2.5mm in length), all screws are the same size so getting them mixed up will not be an issue later on.
    • One of the lower right hand screws will be hidden under a sticker.
  6. Blu Studio HD 6.0 Midframe Replacement: step 6, image 1 of 1
    • After removing all 16 screws you can begin the process of removing the battery housing panel.
    • You will need to use the thinner plastic prying tool to slowly outline the seem of the case starting from the top (near the camera).
    • Try to be careful around the side buttons as the plastic is weakest there.
    • After the top half of the case has been opened insert the thicker prying tool to keep the case open. This will help as the battery and battery housing have a suction cup like action that keeps them from separating.
  7. Blu Studio HD 6.0 Midframe Replacement: step 7, image 1 of 1
    • At this point your battery, motherboard, rear camera, and front camera should all be readily available for fixing. Happy fixing.
2 other people completed this guide.
Erik reinbolt
1,572 Reputation
3 Guides authored
USF Tampa, Team 9-1, Blackwell Fall 2014 Member of USF Tampa, Team 9-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G1
3 Members
8 Guides authored
1 Guide Comment
I have the same phone, This helps me fix the broken screen that i am trying to replace. I need complete screen replacement guide
sandip patel - Reply Share
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 33
All Time: 3,268
