Blu Studio HD 6.0 Rear Case Replacement
Erik reinbolt
Erik reinbolt and 5 other contributors
Last updated on May 22, 2019
1 minute
Easy
Introduction
Go to step 1
In this guide you'll be opening the back panel of your Blu Studio, this is the first step you'll take whenever you replace or add internal parts.
If you don't have any fingernails you may want to use the plastic prying tools.
Tools
  1. Blu Studio HD 6.0 Rear Case Replacement, Rear Case: step 1, image 1 of 1
    • Begin by making sure your Blu Studio is turned off.
  2. Blu Studio HD 6.0 Rear Case Replacement, Back Panel.: step 2, image 1 of 2 Blu Studio HD 6.0 Rear Case Replacement, Back Panel.: step 2, image 2 of 2
    • To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
  3. Blu Studio HD 6.0 Rear Case Replacement: step 3, image 1 of 2 Blu Studio HD 6.0 Rear Case Replacement: step 3, image 2 of 2
    • Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed.
    • Your rear panel should be placed nearby and in a safe location until you are finished with your task.
7 other people completed this guide.
Erik reinbolt
1,572 Reputation
3 Guides authored
USF Tampa, Team 9-1, Blackwell Fall 2014 Member of USF Tampa, Team 9-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G1
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 19
All Time: 2,217
