Blu Studio HD 6.0 Volume Buttons replacement
  1. Blu Studio HD 6.0 Volume Buttons replacement, Rear Case: step 1, image 1 of 1
    • Begin by making sure your Blu Studio is turned off.
  2. Blu Studio HD 6.0 Volume Buttons replacement, Back Panel.: step 2, image 1 of 2 Blu Studio HD 6.0 Volume Buttons replacement, Back Panel.: step 2, image 2 of 2
    • To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
  3. Blu Studio HD 6.0 Volume Buttons replacement: step 3, image 1 of 2 Blu Studio HD 6.0 Volume Buttons replacement: step 3, image 2 of 2
    • Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed.
    • Your rear panel should be placed nearby and in a safe location until you are finished with your task.
  4. Blu Studio HD 6.0 Volume Buttons replacement, Midframe: step 4, image 1 of 2 Blu Studio HD 6.0 Volume Buttons replacement, Midframe: step 4, image 2 of 2
    • With your back panel already removed from the previous guide you'll need to acquire a Philips head screw driver size (PH00)
  5. Blu Studio HD 6.0 Volume Buttons replacement: step 5, image 1 of 1
    • Next proceed to remove all 16 screws (2.5mm in length), all screws are the same size so getting them mixed up will not be an issue later on.
    • One of the lower right hand screws will be hidden under a sticker.
  6. Blu Studio HD 6.0 Volume Buttons replacement: step 6, image 1 of 1
    • After removing all 16 screws you can begin the process of removing the battery housing panel.
    • You will need to use the thinner plastic prying tool to slowly outline the seem of the case starting from the top (near the camera).
    • Try to be careful around the side buttons as the plastic is weakest there.
    • After the top half of the case has been opened insert the thicker prying tool to keep the case open. This will help as the battery and battery housing have a suction cup like action that keeps them from separating.
  7. Blu Studio HD 6.0 Volume Buttons replacement: step 7, image 1 of 1
    • At this point your battery, motherboard, rear camera, and front camera should all be readily available for fixing. Happy fixing.
  8. Blu Studio HD 6.0 Volume Buttons replacement, Locate the volume buttons.: step 8, image 1 of 1
    • The volume buttons are located on the rear-upper-right side of your Blu Studio phone.
  9. Blu Studio HD 6.0 Volume Buttons replacement, Replace the buttons.: step 9, image 1 of 2 Blu Studio HD 6.0 Volume Buttons replacement, Replace the buttons.: step 9, image 2 of 2
    Tool used on this step:
    Buy
    • Using the tweezers lift the volume buttons and unsolder the buttons connection.
  10. Blu Studio HD 6.0 Volume Buttons replacement, Solder the new buttons.: step 10, image 1 of 2 Blu Studio HD 6.0 Volume Buttons replacement, Solder the new buttons.: step 10, image 2 of 2
    • Finally you solder the new buttons to the motherboard of your Blu Studio.
    • Make sure that your buttons are placed as shown in the picture.
Ernesto Diaz
1,759 Reputation
3 Guides authored
USF Tampa, Team 9-1, Blackwell Fall 2014 Member of USF Tampa, Team 9-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G1
3 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 16
All Time: 2,037
