Bonaok Q37 Battery Replacement
  1. Bonaok Q37 Battery Replacement, Battery: step 1, image 1 of 1
    • Power down the microphone before proceeding to the next step.
  2. Bonaok Q37 Battery Replacement: step 2, image 1 of 2 Bonaok Q37 Battery Replacement: step 2, image 2 of 2
    • Hold the handle with your right hand and unscrew towards you.
    • Once the cover is unscrewed completely, remove the handle cover.
  3. Bonaok Q37 Battery Replacement: step 3, image 1 of 2 Bonaok Q37 Battery Replacement: step 3, image 2 of 2
    • Lift up the side edges of the "Caution" sticker to unseal the battery cover.
    • If the battery compartment cover is not sealed with a caution sticker, proceed to Step 4.
  4. Bonaok Q37 Battery Replacement: step 4, image 1 of 2 Bonaok Q37 Battery Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers to push the cover towards the left.
    • Lift up the cover to remove it from the microphone.
  5. Bonaok Q37 Battery Replacement: step 5, image 1 of 3 Bonaok Q37 Battery Replacement: step 5, image 2 of 3 Bonaok Q37 Battery Replacement: step 5, image 3 of 3
    • Push the battery towards the left and lift it up from the (+) side.
    • Remove the battery from the compartment.
  6. Bonaok Q37 Battery Replacement: step 6, image 1 of 1
    • Insert a new battery into the compartment.
    • Make sure you insert the (-) end first, then push towards the left to make room for the whole battery to be pushed into the compartment.
  7. Bonaok Q37 Battery Replacement: step 7, image 1 of 3 Bonaok Q37 Battery Replacement: step 7, image 2 of 3 Bonaok Q37 Battery Replacement: step 7, image 3 of 3
    • Close the lid and seal back with the caution sticker.
    • Screw the handle back on by twisting it away from you.
  8. Bonaok Q37 Battery Replacement: step 8, image 1 of 1
    • Turn the power on and make sure the operating light is blue.
Please charge the device completely before use.
Han Sol Lee
157 Reputation
1 Guide authored
4 Comments
What kind of battery?
Carmen Veguilla - Reply
Which type of battery? I looked on Amazon but can't find it. Must be age related problem, too old for new tech. 😊
Where can I buy replacement battery
Lee Fisher - Reply
NUMBER 18650 3.7volt lithium-ion rechargeable, available online everywhere BUT cannot ship with most carriers so delivery charge is expensive
William Row - Reply
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 70
All Time: 1,801
