Boombotix Boombot Mini Speaker Replacement
  1. Boombotix Boombot Mini Speaker Replacement, Speaker: step 1, image 1 of 3 Boombotix Boombot Mini Speaker Replacement, Speaker: step 1, image 2 of 3 Boombotix Boombot Mini Speaker Replacement, Speaker: step 1, image 3 of 3
    • Twist the front panel of the speaker to the left.
    • Do not try to pry or pop off the front panel.
  2. Boombotix Boombot Mini Speaker Replacement: step 2, image 1 of 3 Boombotix Boombot Mini Speaker Replacement: step 2, image 2 of 3 Boombotix Boombot Mini Speaker Replacement: step 2, image 3 of 3
    • Take out the four screws, then remove the panel that contains the speaker.
  3. Boombotix Boombot Mini Speaker Replacement: step 3, image 1 of 3 Boombotix Boombot Mini Speaker Replacement: step 3, image 2 of 3 Boombotix Boombot Mini Speaker Replacement: step 3, image 3 of 3
    • Take the speaker off of the base.
    • Expose the motherboard and place the speaker next to it.
    • Be careful not to tangle or damage the wires connecting the speaker.
    • This panel will be harder to get off. Use something small such as a card to creat a lip for leverage.
  4. Boombotix Boombot Mini Speaker Replacement: step 4, image 1 of 1
    • Find the connection of the speaker by following the wires.
    • Do not damage the battery. Make sure not to use any metal object to poke around in the device because of possible shock.
  5. Boombotix Boombot Mini Speaker Replacement: step 5, image 1 of 2 Boombotix Boombot Mini Speaker Replacement: step 5, image 2 of 2
    • Now that you have found the wire connection to the motherboard, disconnect it.
    • Pull the wire straight out.
  6. Boombotix Boombot Mini Speaker Replacement: step 6, image 1 of 1
    • Connect the white plug of the new speaker to the motherboard.
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 1,428
