Boosted Board 1st Generation Belts Replacement
  1. Boosted Board 1st Generation Belts Replacement, Rear Wheels: step 1, image 1 of 2 Boosted Board 1st Generation Belts Replacement, Rear Wheels: step 1, image 2 of 2
    • Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
    • Do Not Remove the Screws.
  2. Boosted Board 1st Generation Belts Replacement: step 2, image 1 of 1
    • Compress the motor mount back towards the wheel.
    • While keeping the motor mount compressed, tighten one of the hex nuts that you loosened in the previous step.
    • The motor mounts are spring tensioned so it is necessary compress them to loosen the belts.
  3. Boosted Board 1st Generation Belts Replacement: step 3, image 1 of 2 Boosted Board 1st Generation Belts Replacement: step 3, image 2 of 2
    • Remove the axel nut with a 1/2" socket wrench
  4. Boosted Board 1st Generation Belts Replacement: step 4, image 1 of 3 Boosted Board 1st Generation Belts Replacement: step 4, image 2 of 3 Boosted Board 1st Generation Belts Replacement: step 4, image 3 of 3
    • Rotate and pull counterclockwise until the wheel comes off the axle completely.
    • The front washer will come off with the wheel.
    • Remove the back washer from the axle.
    • Replacing the wheel requires the bearings to be switched into the new wheel.
  5. Boosted Board 1st Generation Belts Replacement, Belts: step 5, image 1 of 3 Boosted Board 1st Generation Belts Replacement, Belts: step 5, image 2 of 3 Boosted Board 1st Generation Belts Replacement, Belts: step 5, image 3 of 3
    • Compress the motor mount back .
    • Slide the belt off the axle
  6. Boosted Board 1st Generation Belts Replacement: step 6, image 1 of 1
    • Remove the two hex screws.
    • Remove the front hex screw.
    • When removing the Front hex screw, hold the motor mount and the truck together.
    • The springs inside the motor mount will push the motor out of the casing if they are not held together.
  7. Boosted Board 1st Generation Belts Replacement: step 7, image 1 of 3 Boosted Board 1st Generation Belts Replacement: step 7, image 2 of 3 Boosted Board 1st Generation Belts Replacement: step 7, image 3 of 3
    • Making sure to hold the motor and truck together, lift off the belt casing and take off the belt.
    • Do Not let go of the motor and truck until the new belt is on and the Front hex screw is tightened securely.
4 other people completed this guide.
Emily Imfeld
532 Reputation
4 Guides authored
Cal Poly, Team 15-7, Livingston Fall 2016 Member of Cal Poly, Team 15-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G7
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 1,628
