Bosch 3727DEVS Power Cord Replacement
  1. Bosch 3727DEVS Power Cord  Replacement, Power Cord: step 1, image 1 of 3 Bosch 3727DEVS Power Cord  Replacement, Power Cord: step 1, image 2 of 3 Bosch 3727DEVS Power Cord  Replacement, Power Cord: step 1, image 3 of 3
    • Ensure that the power chord is not plugged into an outlet.
    • Using the T20 Torx Screwdriver, remove the four 15.6 mm screws securing the top cover to the sander.
    • Lift the top cover off the sander.
  2. Bosch 3727DEVS Power Cord  Replacement: step 2, image 1 of 3 Bosch 3727DEVS Power Cord  Replacement: step 2, image 2 of 3 Bosch 3727DEVS Power Cord  Replacement: step 2, image 3 of 3
    • Using the T20 Torx Screwdriver, remove the two 15.6 mm screws securing the cable clip to the motor housing.
    • Lift cable clip and cord from motor housing.
  3. Bosch 3727DEVS Power Cord  Replacement: step 3, image 1 of 3 Bosch 3727DEVS Power Cord  Replacement: step 3, image 2 of 3 Bosch 3727DEVS Power Cord  Replacement: step 3, image 3 of 3
    Tool used on this step:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Buy
    • Using the 2.5 mm Flathead Screwdriver, loosen the two screws securing the white and black wires to the On/Off Switch.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 499
