Bosch MFQ 36440 Disassembly
  1. Bosch MFQ 36440 Disassembly, Remove screws: step 1, image 1 of 1
    • Remove 2x Torx screws (size 10) on the front
  2. Bosch MFQ 36440 Disassembly, Remove the grey front cover: step 2, image 1 of 2 Bosch MFQ 36440 Disassembly, Remove the grey front cover: step 2, image 2 of 2
    • Remove the front cover
    • Gently push downwards the cover, then pull it through the holes
    • Once it is detached at the top, slide the entire gray cover down
  3. Bosch MFQ 36440 Disassembly, Detach the two sides of the mixer's white case: step 3, image 1 of 3 Bosch MFQ 36440 Disassembly, Detach the two sides of the mixer's white case: step 3, image 2 of 3 Bosch MFQ 36440 Disassembly, Detach the two sides of the mixer's white case: step 3, image 3 of 3
    • The first step is somewhat tricky. Use a long screwdriver to release the first part at the top.
    • Continue your way all around the case.
    • The clip on top front is tricky a long and thin flat screwdriver is needed
    • The clip on very top is impossible to release you need to pry the two half’s carefully apart until the top releases
  4. Bosch MFQ 36440 Disassembly, Assembly: step 4, image 1 of 2 Bosch MFQ 36440 Disassembly, Assembly: step 4, image 2 of 2
    • Prop everything back into the half without the clips
    • Take care about the safety cam to be aligned in the cover
8 other people completed this guide.
Stanky
1,358 Reputation
6 Guides authored
2 Guide Comments
Hey, so what does “Continue your way all around the case” mean? I got the one clip open which you pictured, and then I got the case open just a tiny bit more, but now I’m stuck.
Could someone perhaps detail the last steps more? :(
Carsten Hagemann - Reply Share
When you put it together again use the side with the cable “channels”, it is way easier than with the other side.
Tobias Vdb - Reply Share
Past 24 Hours: 9
Past 7 Days: 48
Past 30 Days: 255
All Time: 10,563
