Bosch Maxx WFL2455 Washing-Machine Front panel disassembly
  1. Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Lower cover: step 1, image 1 of 2 Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Lower cover: step 1, image 2 of 2
    • Unplug your device.
    • Remove the cover hiding the drain hole.
    • Remove the T20 Torx screw which is holding the lower cover.
    • Remove the lower cover by sliding it to the right.
  2. Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Detergent dispenser: step 2, image 1 of 1
    • Remove the detergent dispenser by opening it then by pressing on the notch with your finger.
  3. Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Drum gasket ring: step 3, image 1 of 2 Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Drum gasket ring: step 3, image 2 of 2
    • Remove the ring holding the drum gasket.
    • Start with the spring located near the window hinge.
    • Avoid using sharp or cutting tools to avoid damaging the gasket.
  4. Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Drum gasket: step 4, image 1 of 2 Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Drum gasket: step 4, image 2 of 2
    • Insérez ici votre traduction
    • Move the gasket to the inside of the drum so that it won't bother when you'll be removing the front panel.
  5. Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Front panel mounting screws: step 5, image 1 of 2 Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Front panel mounting screws: step 5, image 2 of 2
    • Remove the two T20 Torx screws located below the front panel.
    • Remove the T20 Torx screw located in the detergent dispenser slot.
  6. Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Removing the front panel: step 6, image 1 of 2 Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Removing the front panel: step 6, image 2 of 2
    • The front panel is held in place by a strip, held by the previously removed screw of the detergent dispenser slot.
    • To remove the front panel, start by sliding it downwards (it should normally fall under its own weight).
  7. Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Front panel's connections: step 7, image 1 of 2 Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Front panel's connections: step 7, image 2 of 2
    • There's an electrical connection between the body of the device and the front panel (probably a window sensor).
    • Disconnect the window sensor by lifting the connector's tab and by pulling it down firmy.
    • On the second picture, the connector is shown partially disconnected.
  8. Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Wire guide: step 8, image 1 of 3 Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Wire guide: step 8, image 2 of 3 Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Wire guide: step 8, image 3 of 3
    • Remove the guide from the front panel.
    • And voila, the front panel is disassembled!
4 other people completed this guide.
Special thanks to these translators:
fr en
100%
Haitham is helping us fix the world! Want to contribute?
Start translating ›
Haitham
329 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 7
Past 7 Days: 80
Past 30 Days: 337
All Time: 13,376
