Bosch Oven HGI8054UC Igniter Replacement
  1. Bosch Oven HGI8054UC Igniter Replacement, Remove Oven Door - Cautions: step 1, image 1 of 1
    • Caution advice from my Bosch Owners Manual
    • Make sure oven is cool and power to the oven has been turned off before removing the door. Failure to do so could result in electrical shock or burns.
    • The oven door is heavy and parts of it are fragile. Use both hands to remove the oven door. The door front is glass. Handle carefully to avoid breakage.
    • Grasp only the sides of the oven door. Do not grasp the handle as it may swing in your hand and cause damage or injury.
    • Failure to grasp the oven door firmly and properly could result in personal injury or product damage.
    • To avoid injury from hinge bracket snapping closed, be sure that both levers are securely in place before removing the door. Also, do not force door open or closed—the hinge could be damaged and injury could result.
    • Do not lay removed door on sharp or pointed objects as this could break the glass. Lay on a flat, smooth surface, positioned so that the door cannot fall over.
  2. Bosch Oven HGI8054UC Igniter Replacement, Removing the Oven Door: step 2, image 1 of 3 Bosch Oven HGI8054UC Igniter Replacement, Removing the Oven Door: step 2, image 2 of 3 Bosch Oven HGI8054UC Igniter Replacement, Removing the Oven Door: step 2, image 3 of 3
    • From my Bosch Owners Manual
    • Open the oven door to its fully open, horizontal position.
    • Flip levers on hinges toward you. Note: It may be necessary to use a tool, such as a screwdriver, to gently pry the upper part of the lever away from the housing. Take care to avoid scratching the housing.
    • Bring both door hinge levers to their fullest down position as shown in the illustration. The left and right door hinge levers may differ slightly but operate in the same manner.
    • Close the oven door until it catches on the hinge stop levers, locking the hinges at the proper angle for door removal. The door will be open about 7 inches at the top. This takes the spring tension off the hinges so the door can be easily lifted out.
    • The door is heavy. Use both hands to firmly grip it by the sides. Do not grip the door by the handle. Maintaining the door angle, lift the door straight up approximately 3/4" to unhook the hinges from the slots and then pull it out towards you until the hinges are clear of the oven housing.
    • Place the door in a convenient and stable location for cleaning.
  3. Bosch Oven HGI8054UC Igniter Replacement, Remove Oven Racks: step 3, image 1 of 1
    • Racks slide out and tip upward to remove.
  4. Bosch Oven HGI8054UC Igniter Replacement, Remove oven bottom panel: step 4, image 1 of 2 Bosch Oven HGI8054UC Igniter Replacement, Remove oven bottom panel: step 4, image 2 of 2
    • The oven gas burner and the igniter are under the panel at the bottom of the oven.
    • Remove the two screws at the back of the oven and pull up on the bottom panel to remove.
    • Set the panel aside.
  5. Bosch Oven HGI8054UC Igniter Replacement, Replace Igniter: step 5, image 1 of 1
    • The igniter is about 3-inches long, with two pre-stripped wires coming off it.
    • Remove the old igniter by removing the two holding screws, and disconnecting the wire-nuts that connect it.
    • Install the new igniter by reversing these directions.
2 other people completed this guide.
6 Comments
I've worked on appliances for over 25 years. One thing you left out is that you could have put in a Frigidaire brand ignitor (part number 5303935066) and gotten the same results. A square ignitor is a square ignitor no matter the brand. The Frigidaire ignitor can be found online for $20 or less.
Thom Scott
Thom Scott - Reply
Thanks Thom. I had no idea, but that makes a lot of sense. Jim J
Jimjar -
My screws 100% rusted on. Fused with the metal. Is there a entire stovetop assembly that can be purchased?
J S - Reply
I have no idea. I would try to drill the rusted screws out with an electric drill.
Jimjar - Reply
I pulled out the igniter but the two wires are still plugged in somewhere that's not visible. How do you get to the location where the igniter plugs in?
cgaspara - Reply
Past 24 Hours: 3
Past 7 Days: 40
Past 30 Days: 227
All Time: 6,408
