Bosch PS21 Trigger Replacement
  1. Bosch PS21 Trigger Replacement, Battery: step 1, image 1 of 1
    • Pinch the two release tabs on the sides of the battery, and slide the battery out.
  2. Bosch PS21 Trigger Replacement, Trigger: step 2, image 1 of 2 Bosch PS21 Trigger Replacement, Trigger: step 2, image 2 of 2
    Tool used on this step:
    $3.99
    Buy
    • Locate the clip that connects the two halves of the outer casing on the rear edge of the battery shaft. *Use the angled tweezers to remove the clip.
    • Place the tweezers in the groove on the inside of the clip. Use your other hand to firmly brace the drill and pull towards your body until the clip comes loose.
  3. Bosch PS21 Trigger Replacement: step 3, image 1 of 3 Bosch PS21 Trigger Replacement: step 3, image 2 of 3 Bosch PS21 Trigger Replacement: step 3, image 3 of 3
    • Locate the eight 5.5 mm screws located on the upwards facing side of the drill.
    • Remove each screw using the T8 Torx driver, set aside in a safe place.
    • After removing all the screws, use a small or medium metal spudger remove the casing to expose the motor and trigger.
  4. Bosch PS21 Trigger Replacement: step 4, image 1 of 2 Bosch PS21 Trigger Replacement: step 4, image 2 of 2
    • Place a finger under the metal tab seen here and lift gently up to free the trigger mechanism.
    • Carefully grab the trigger assembly and gently pull upwards without taking too much out of place.
  5. Bosch PS21 Trigger Replacement: step 5, image 1 of 2 Bosch PS21 Trigger Replacement: step 5, image 2 of 2
    • Gently disconnect the two wires connecting the motor to the trigger utilizing a pair of pliers.
    • The trigger assembly is Part #:1607233422
6 other people completed this guide.
Getsemani Gonzalez
306 Reputation
2 Guides authored
IUPUI, Team 1-2, Harley Spring 2016 Member of IUPUI, Team 1-2, Harley Spring 2016
IUPUI-HARLEY-S16S1G2
4 Members
4 Guides authored
2 Guide Comments
mine has always operated flawlessly, then I was putting a few screws in the bedroom shelf and it worked fine. picked it up to change rotation and it is froze up. the trigger operates the lite and the batteries are fresh. but it will not turn, tried to turn with a wrench but its locked ? motor? gear drive or trigger? It doesn’t even seem as if its trying to turn when you pull the trigger?
roadkingrick - Reply
The most difficult step in this process is disconnecting the black wire from the defective switch. The wire enters the switch block however there is no sign of a screw or fastening one can disconnect to remove that wire! That step is ‘glossed over’. Any enlightenment from anyone would be welcome.
Tony Savage - Reply
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 47
All Time: 5,915
