Bosch battery drill/bit PSR 9,6 VE-2 battery pack repair
  1. Bosch battery drill/bit   PSR 9,6 VE-2 battery pack repair, Remove the screws and lift the lid: step 1, image 1 of 2 Bosch battery drill/bit   PSR 9,6 VE-2 battery pack repair, Remove the screws and lift the lid: step 1, image 2 of 2
    • Loosen and remove the four screws with a Torx T 10 screwdriver (in a pinch you can use a flat screwdriver).
    • One of the screws is secured by a 3 mm high green cap (green marker) . I used a small screwdriver to pry it free, regrettably not without some scratches.
    • While pressing the red locking tabs remove the upper part from the lower part.
  2. Bosch battery drill/bit   PSR 9,6 VE-2 battery pack repair, Remove the battery pack: step 2, image 1 of 2 Bosch battery drill/bit   PSR 9,6 VE-2 battery pack repair, Remove the battery pack: step 2, image 2 of 2
    • Remove the red tabs by pressing them in, the metal springs may drop out of their positions but are easy to reposition.
    • Carefully remove the 8 cell battery pack.
  3. Bosch battery drill/bit   PSR 9,6 VE-2 battery pack repair, Measure the cell voltage: step 3, image 1 of 1
    • Take a picture of the cells' layout for reassembly.
    • Remove the foam rubber underneath the cells.
    • Now you can remove the spacer between the 7 cell-hexagon and the one upper remaining cell.
    • Measure the voltage from each individual cell, the reading should be upward from 0.8 V, if not the cell is broken and has to be replaced.
    • You'll need 8 working cells... Good luck !
  4. Bosch battery drill/bit   PSR 9,6 VE-2 battery pack repair, Removal of working cells and reassemble together: step 4, image 1 of 2 Bosch battery drill/bit   PSR 9,6 VE-2 battery pack repair, Removal of working cells and reassemble together: step 4, image 2 of 2
    • the (welded?) connections between the cells can be pried off as best as possible with a flat screwdriver and then separated with pliers
    • Make sure that the cells can be connected as well as possible by soldering them together afterwards. Soldering is done at a high temperature because the heat dissipates quickly. If necessary, a wire must be soldered in between.
    • Pay attention to the polarity (but it's actually clear)
    • Carefully detach the head with the connectors and the thermal resistor and reassemble correctly after assembly
  5. Bosch battery drill/bit   PSR 9,6 VE-2 battery pack repair, Reassemble and charge: step 5, image 1 of 1
    • Measure the total voltage of the assembled cells. It should be 7V or more.
    • Reattach the foam rubber, align using the cells' imprint on it.
    • Put back together in de plastic packholder. Charge a few times. I had to charge the pack three times until I had an acceptable amount of stored energy. But the drill works again.
To reassemble your device , follow the steps in reverse order.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Peter Scholl
1,440 Reputation
6 Guides authored
AEG-Make&Repair AG Member of AEG-Make&Repair AG
Local Repair Groups
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 6
Past 7 Days: 17
Past 30 Days: 56
All Time: 994
