Bosch mfq 1901, suddenly does not start fix
  1. Bosch mfq 1901, suddenly does not start fix, Dissasembly: step 1, image 1 of 1
    • Using a flat head screwdriver carefully push the gray bar backwards.
    • Open it like a suite case as there where hinges aligning with the flat underside.
    • It should pop up fairly easy
  2. Bosch mfq 1901, suddenly does not start fix, Locate the broken plastic piece: step 2, image 1 of 2 Bosch mfq 1901, suddenly does not start fix, Locate the broken plastic piece: step 2, image 2 of 2
    • The blue line corresponds to how the plastic should align
    • The red arrow shows where it has broken.
    • Picture 2 shows the remainer of the plastic speed regulator
  3. Bosch mfq 1901, suddenly does not start fix, (Bonus) observe the electronics: step 3, image 1 of 1
    • There is a diode(black), a safety capacitor(white), another capacitor(blue) and a coil
    • The white capacitor is an KNB1530 MKP-X2, 0,022uF, rated for 275VAC
  4. Bosch mfq 1901, suddenly does not start fix, Merge the two pieces together: step 4, image 1 of 1
    • Use kapton tape or some other, thin heat resistent, low friction and electrically isolating tape.
    • By merging the two broken pieces and putting one piece of tape(I used 8 cm to make sure other parts will hold) on each side of the broken area.
    • Apologies of no picture of the result.
    • You can also replace the part with a new one: Part# Bosch 640243 from https://www.bosch-home.com/de/supportdet...
  5. Bosch mfq 1901, suddenly does not start fix, Reassembly: step 5, image 1 of 2 Bosch mfq 1901, suddenly does not start fix, Reassembly: step 5, image 2 of 2
    • Make sure the spherical cable holder is in place(obviously not like in the picture)
    • Use the same methodology as for dissasembly, let all parts stay in the left shell-piece
    • Align the two shell-parts with an 90-degree at the flat bottom as there where an hinge there
    • Do not use much force, this proceedure should be smooth, so be paitent
    • Latsly, push the gray speed-dial area back with a small flat screwdriver to let the last gap dissapear
  6. Bosch mfq 1901, suddenly does not start fix, Testdrive!: step 6, image 1 of 1
    • I did put it on a heat resistant non flammable surface, set the speed controller to zero.
    • Plug it out
    • Repeat the first step but with the speed controller set to something else
    • Mine spins better than ever! (Or maybe I was just exicted)
Finish Line
3 other people completed this guide.
Endorph
2,145 Reputation
7 Guides authored
5 Comments
Super Hilfe. Ich bin immer überrascht, dass das schon einer vorher repariert hat und sich sogar die Zeit nimmt alles zu dokumentieren. Phantastisch.
Stefan Burmeister - Reply
Mit diesem umreifungsband das um schwerere Packete manchmal gewickelt wird kann man das Teil wenn's schon sehr spröde ist komplett ersetzen. Doppelt nehmen.
Imre Jones - Reply
Danke aus Griechenland
Stergios B - Reply
Many Thanks ..you save my Mixer .
Kazim ERGUNEY - Reply
Ich habe statt zu Kleben auf der Aussenseite des Kunststoffbandes Zwirne gebunden. Eine doppelt geletge Schlaufe um die beden Stifte am Ende und oben zugebunden. Druck nach unten überträgtt das Band an der Stoßstelle, Zug nimmt der Faden auf. Mal sehen wie lange es hält.
Dirk Flackus - Reply
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 60
All Time: 6,051
